CL-Class (W215) 2000-2006: CL 500, CL 600
ABC freaking out world record
Old Dec 16, 2016 | 04:01 PM
pmercury's Avatar
member
CL
Exclamation ABC freaking out world record
Hi, not that i'm mad about the ABC failing again but curious. I'm going to junk the ABC for adjustable coilovers
I've had front drops when parked last weeks and then, suddenly everything stopped and had the car blocked in high position and the ABC, drive carefully RED light" on dash as soon as I startup
now, my french friend hooked up his DAS and the whole ecu is in error as we can't even erase the error codes.
voltage on module is ok, fuses ok relay ok
maybe some wiring went wrong when I lowered the subframe ?
weird
anyone any idea where I could look, just for sport and curiosity ?
THX !
Old Dec 16, 2016 | 07:00 PM
ItalianJoe1's Avatar
2003 CL 600
Sounds electrical. Very possible you damaged some wiring in your repairs, but I don't know where to say to look. There was very little wiring in the way for the subframe drop when I did it.
Old Dec 16, 2016 | 07:06 PM
pmercury's Avatar
member
CL
Or maybe just a coincidence, but in das I see 225 bar
really, any test ideas are welcome
pmercury's Avatar
member
CL
anyone ever seen the ABC module going wrong ?
I say that because I removed and opened the module to look inside in case
and on the outside back I saw "new" marker written
................ not the original one ? maybe second time the module freaks out ?
Old Dec 16, 2016 | 07:16 PM
2003 CL 600
your value of 255 is the max value for digital systems, so that's probably an electrical error.
We do that when testing with a new module at work, sometimes you have the new and old ones out and they look exactly the same, so it's nice to mark them so you don't confuse yourself further by putting the old one in and expecting something to change.
Old Dec 16, 2016 | 07:31 PM
pmercury's Avatar
member
CL
just ordered a new module, latest version Q10
just 53$
worth to try, just for fun
Old Dec 16, 2016 | 07:32 PM
pmercury's Avatar
member
CL
which means that the module has probably been changed then lol
Old Dec 18, 2016 | 12:55 PM
biker349's Avatar
cl600
good to know. thanks
Old Dec 18, 2016 | 01:21 PM
pmercury's Avatar
member
CL
stupid pump is dead
ordered a rebuild
Old Dec 18, 2016 | 03:08 PM
2003 CL 600
Originally Posted by pmercury
stupid pump is dead
ordered a rebuild
How? A dead pump can't raise the car to max and show 250 bar pressure... Just curious as to what happened to cause this.
Old Dec 18, 2016 | 03:26 PM
pmercury's Avatar
member
CL
nope
if you see 225 that is the sensor limit
in fact, it's no longer measuring
also, when the system fails, the valves close and don't reopen until its fixed
preventing the car to drop
i've been told this by my friend who has a little garage only repairing MB
Old Dec 18, 2016 | 03:27 PM
pmercury's Avatar
member
CL
the only thing he and I don't understand is why we can't erase the abc faults
that's why I bought a new module just in case
Old Dec 18, 2016 | 10:59 PM
2003 CL 600
If the pump is dead the pressure will read zero. Yes it won't drop, but it won't jack up past normal height. You have some other sort of problem going on.
Old Dec 19, 2016 | 01:29 AM
pmercury's Avatar
member
CL
I sure have
front was dropping sometimes stationary
and all the time after parked a few hours, but not when I parked on position high
and, as I said, i'm afraid the module is not working correctly
Old Dec 19, 2016 | 01:30 AM
pmercury's Avatar
member
CL
but as i'm getting coilovers, I might not rebuild the valves now
