CL-Class (W215) 2000-2006: CL 500, CL 600
Yellow speed conversion
Old Nov 19, 2017 | 02:43 PM
  #51
KeySL's Avatar
'97 CLK320 '94 SL 320
Originally Posted by Ste73
Just wanted to say my car had its first MOT test today after fitting the coilovers and passed with no problem. I had concerns about the lack of sway bars & message on dash ( instrument cluster abc visit workshop) in white which I can delete with R button but it was fine.
Mot's were something I had concerns about when I did it but they were fine about it.
The mot mot is an annual safety test in Great Britain by the way for those of you in other countries!
Ste, I'm in the UK too. Could you send me a link to the parts you ordered please. My ABC system is fine at the moment (touch wood) but when it starts to play up I'm going to go this route.
Many thanks!
Old Aug 15, 2018 | 11:45 AM
  #52
pauls1776's Avatar
W215 cl500 2002
ive just ordered my yellowspeeds for a cl500,..i was reluctant to do it because my car had a new ABC pump installed 4.5k miles ago,by the previous owner,..,but the valve block at the rear just exploded,greenish fluid all over the floor but the suspension is still sitting fine,..BUT..if this valve block has gone the next is sure to be not far behind,,as well as accumulator replacements,,and who knows what else...so i,m running from the ABC route now,before i throw any such money at it,,i know its a cadinal sin to most people, but, i dont want to chuck £5-6k to be in a horrible cycle,,,so reading this thread as well as others i decided its the way to go,,the car is far to good to scrap.!...so how are you all getting on since your changeovers after time..?..and how did you eventually manage with the ABC dash warning ?
Old Aug 15, 2018 | 12:36 PM
  #53
smartadze's Avatar
2003 CL-500
IMO, you're doing the right thing at the right time :-). I'm very happy with the YellowSpeed conversion.
I don't mind the resulting "white" dash warning - you just cancel it out with the "R" button. I don't mind doing this as a regular part of startup, but others find the $350-or-so for the Strutmaster's box to be a good investment (making any warnings go away forever). For a while, S-master's wouldn't sell the box separately, but I'm told that they now will do just that.
Old Aug 15, 2018 | 01:12 PM
  #54
pauls1776's Avatar
W215 cl500 2002
thanks for the confidence boost. did you use a new s500 steering pump ?...or did you leave in the other,?. i could probably get some money back by selling what i take out..i also just saw the price on the small electronic box .. $540 inc shipping !..and that will be probably subjest to import vat ?.. someone could make a right little earner if they were electronically minded.!.i wonder if there is someone out there with a mate ..i,ll press the R button instead.no problem !
Old Aug 15, 2018 | 01:54 PM
  #55
smartadze's Avatar
2003 CL-500
Both methods shown here previous post regarding pumps
Old Aug 15, 2018 | 02:17 PM
  #56
pauls1776's Avatar
W215 cl500 2002
thats excellent help,. i,m thinking now to take your advice and leave it in place with a re route of the lines,.as i know the pump is perfect, and for the sake of messing around to make a couple of hundred quid back its not worth the hassle !..especially as we will have to drain the fluid and refill etc etc, and a new resevoir,..great help all around,,thank you...ive got a competent mechanic to do the job with me,so i,ll show him this to see if he knows the pipe reroute, unless its on here already and ive not seen it as yet...
Old Aug 16, 2018 | 09:52 AM
  #57
pauls1776's Avatar
W215 cl500 2002
ive studied both of the above regarding which pump etc, ive actually decided now to order a seperate hydraulic ps pump,as the splicing or re routing of lines does actually look like a cumbersome task,.and didnt want to have any further "not knowings" if its correct or not..apart from the headwork. the only difficulty i did find was locating the correct pump with the bracket,.in fact the only one i could find was a new bosch K S00 000 624 with one attached..now i know it wasnt cheap,.but in the whole realm of things i have a quality pump that i can rely on..i couldnt even find a seperate bracket,.so for peace of mind i got this..youve been hugely helpful and i cant thank you enough..now i await my deliveries.!
the cost of the yellow coilovers and this pump came to just over a £1050 ...apart now from looking after my friend the mechanic who is a great friend,i,ll have a piece of mind new install without waiting for the flashing lights on the dashboard !
Old Sep 6, 2018 | 05:34 PM
  #58
Sebmel123's Avatar
2003 s600
I completed my YSR coilover conversion about two weeks ago now. I ordered the 20kg spring rate for the rear coilovers but, I'm discovering that they are a little too stiff for what I'm looking for. I'll be replacing them with 14kg springs in a few days but thought I would see if someone on the forum would be interested in a set of 20kg springs. BTW, these are on a 03 s600. Please PM me if anyone is interested.
Old Nov 24, 2018 | 12:34 AM
  #59
ctravis595's Avatar
2002 CL500 to CL55 conversion
Those are some really nice looking CL’s guys.. can’t wait for my yellow speeds to get here next week and finally have the car lowered again!!!
anybody have any recommendations on settings? I ordered 16/16 front and rear spring rates and I understand it’s not easy to adjust the coilovers after they are installed...
Old Dec 1, 2018 | 08:07 PM
  #60
ctravis595's Avatar
I'm sure this link applies to the strut masters kit which i dismissed due to its ridiculous cost to the uk & its even more ridiculous ride height. I'm at 26.5" front & 27" rear from ground to top of arches on 19" rims ( very low). There seems to be lots of concerns about sway bars when doing the yellowspeed conversion. My personal advice is buy a cl 215, fit the yellowspeeds, set them up & then go & enjoy how unbelievably well it takes bends without sway bars, its quite strange how a suspension system can be so compliant when driving normally yet so stiff as it piles into a corner at high speeds.
i'm considering adding front sways at least, to counter the unsafe bounciness at high speeds with bumpy roads. otherwise yes the system does not allow much body roll suprisingly
Old Jan 14, 2020 | 01:47 AM
  #61
Ricardo M's Avatar
CL500
hi new here, just completed a full conversion to coilovers including all of the abc removal inc, pump. W220 steering pump fitted, and I've gotta say having owned the car 14 months it is the best thing I've ever done. It's a 2000 cl500 car handles & drives really well. It feels more alive and predictable all round
Hi Ste73, have you still got the CL500?
How's it doing on the coilovers?
Old Jan 15, 2020 | 04:57 PM
  #62
BoxxMann's Avatar
02 CL500 | 06 E350 4M
I just did my CL500 with YS Coils and it's good. Worth the money. YS USA has a set of coils for the W215 on open box for 850. Just make sure they are the slanted tops if you buy them.
Old May 5, 2020 | 09:52 PM
  #63
Sportunage's Avatar
2005 W215 CL55 AMG
I saw those after I placed my order. They are still there or they have different open box set for sale.
Old Aug 13, 2020 | 04:47 PM
  #64
RoadRaceM3's Avatar
2006 CL500
Just ordered a set of Yellowspeeds for my '06 CL500. Tandem pump is howling at 1000-1500 RPM, A few metal shavings in the fluid as well, it's only a matter of time before it fails. Going to replace the tandem pump as part of the process with just a W220 PS pump, remove as much of the plumbing and hydraulic hardware as possible, and see how it ends up. This thread and a few others have been instrumental in providing the info needed for me to make the decision - thanks all!
My '06 CL500
