Intercooler bleeding tool (final version)
IMPORTANT ! : if you do not vacuum the intercooler with a system like this, YOU WILL NEVER GET THE BUBBLES OUT ! NEVER !
connector conversion kit:
2pcs 1/4 Inch Adapter Converters R12 to R134a Adapter
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=1%2F4+Inc h+Adapter+Converters+R12+to+R134a+Adapter&_sacat=0
just grind the threat of and connect a hose if you don't have a adapter to hose
R134a AC Air Condition High Low Side Adjustable Quick Coupler Connector Adapter
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=R134a+AC+ Air+Condition+High+Low+Side+Adjustable+Quick+Coupl er+Connector+Adapter&_sacat=0&LH_TitleDesc=0&_osac at=0&_odkw=1%2F4+Inch+Adapter+Converters+R12+to+R1 34a+Adapter
You need a good vacuum pump
find that on second hand site or ebay
I used 5 water filter housings I connected because those don't implode with vacuum and I bleed by 5 liter cans
you can use any of course
You have to cycle at least 25 liters of coolant to get it bubble free if you have a upgraded pump.
If you have a AMG upgrade coolant tank, unplug the tank, fill it from the back (it's impossible to fill it up completely from the top)
then plug it back in.
(adapters Idea is not mine, I don't recall who but it is here somewhere)
Have fun !
UPDATE 2020.04:
I found the origine 2 tools for a low price
this for those who are not able to make a bleeding tool themselves:
https://www.mboemparts.com/oem-parts...e-285589002100
https://www.mboemparts.com/oem-parts...n-285589012100
found new product that might fo the tank job
https://www.aliexpress.com/item/1000005451480.html
10-20 L / 2.5 - 5 gallon
so I can replace my 5 boring to empty filter housings
I have some question that can be here for others:
1. Car must to be after ride or cold when doing that procedure ?
2. How long it take to bleed 5L of coolant with your pump ?
( I found it in web and it probably has efficiency about 31L per min )
3. Can you make quick instruction and tips how to do bleeding step by step ?
Have nice day.
https://mbworld.org/forums/cl-class-...-bleeding.html
I bought a used laboratory version for 20$
you can line up cheap filter housings like me or find a nice vacuum proof tank
so that is why I search a 5 gallon tank
no need to empty and release pressure 4 time before you finish
also, I connect a 100L air tank between the system to maintain good regular vacuum
It will also work correctly when vacum pump like on photo will connect directly to tanks ?
I found 20L tank for you:
http://vacuumchambers.eu/de_DE/p/Vak...ium-VC3028A/22
I bought a vacum pump like on photo.
It is litte bit stranger than yours, I don't know that is fine.
It
It
I have a swirl pot that diverts 5% flow through from the top bleed valves at all times, this keeps air out of the system.
The Mercedes way is:
Pull a vacuum on the system, flip valve and then vac full the system.
Once run, suck coolant from the intercooler bleed valves with a y pipe and a vacuum box until bubbles don't appear (approx 15 L)
But basically same thing. Swirl pot works really well.
vacuum pump pulls the coolant from fresh tank you placed on the tool on the refill cap
only use what I designed with a vacuum pump
Unfortunately the cheap and common compressed air and piston vac pumps don't go deep enough.
How deep do you need to go? It depends on the ambient temperature, but typically 1kPa is adequate (one atmosphere is 101.325 kPa).
Single stage refrigeration vac pumps go well below that, and are reasonably cheap and readily available. They go down to about 5 or 10 Pa if I recall correctly.
Why 1kPa? Water boils at ambient temperature at that pressure, so whatever is left in the IC system will evaporate and fill the system with water vapour. That removes all the air, not just 99% of it. Therefore no more bubbles.
Nick
There's no explicit mention on their website of the specific heat capacity of their coolant, which makes me assume that it's not as high as water.
This all sounds like using 100% anti-freeze, which nobody recommends.
Nick
Nick
very good comment, can you also show links to some of these, second hand or new ?
Nick
Nick, Just got this for a superfast bleeding tool V3
that should do the job
I assume you hook one up to the "outlet" of a vac bleeder (IE the pipe that comes out of the other end of the venturi)
