W215 Engine Fault : P0106 & P0123
The check engine sign appeared about a week ago just after I tried to accelerate faster. And then it took nearly 30 secs to go from 0-20kph -_- . The problem would go after the engine is switched off. The car is experiencing no problem if I'am accelerating slowly. So before taking my car to any mechanic, I decided to check the error codes & therefore purchased a Bluetooth OBD2 Scan Tool & installed Torque Pro app on my mobile device. I got these 2 error codes :-
1- P0106 - Powertrain
Manifold Absolute Presure/Barometric Pressure Circuit Range/Performance Problem
2- P0123 - Powertrain
Throttle/Pedal Position Sensor/Switch A Circuit High Input
Please if anyone experienced similar issues do advice and help me out.
I will proceed to replace the pedals 1st & then see if the problem is solved. To avoid buying a wrong one, can you provide me the part number or the exact name ?
Also, Right now what Im really struggling is finding the Cigar fuse. I know there are 2 fuse boxes on the front engine bay and 1 at the rear seat. Can someone please take a picture of another fuse box location ? Im searching for fuse 86
2203000004 or 2203000104 are the pedal part #, for a 99-02 and an 03-06 respectively, I don't know what year your CL is.
I could use it everyday without problem it i don't accelerate so hard that i press the pedal to the floor. As soon As I floored the pedal , it would go into limp mode
