CL-Class (W215) 2000-2006: CL 500, CL 600
Replace tandem ABC pump with ... ? power steering pump
Old Sep 12, 2019 | 08:39 AM
smkoss's Avatar
2002 c240 and 2001 clk430
HAVE A LINK TO YOU POST I CANT FIND IT???
Old Dec 4, 2019 | 11:08 AM
Salazar64's Avatar
2003 SL500 R230
DIY Coding Out ABC on R230
file:///C:/Users/gmd_b/Desktop/PDF%2..._R230_Cars.pdf
I have also included a PDF file with the instructions and Screen Shots I received from another Blog.
Old Jan 21, 2020 | 09:05 PM
MistaJ504's Avatar
2005 Mercedes S600
I'm completing my Ceika coilovers install and am at the pump swap, however I'm thinking....why not gut the high pressure side of the tandem pump and reinstall original pump??? I'll give it a shot with results shared if it does or doesn't work. Pump already ran dry when the hose burst so I'm guessing it already has some internal damage on the ABC side.
Old Jan 22, 2020 | 01:25 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
it was years ago but I believe I ran my high pressure side dry, and daily drove the car that way for months. Maybe even a year? And the power steering side of the pump worked fine.
given what I understand now about belts, bearings and pulleys. I probably wouldn’t attempt this again, but maybe this info is useful to you
Be sure to share which settings/setup you chose with your Cieka kit!
Old Jan 22, 2020 | 10:36 AM
MistaJ504's Avatar
2005 Mercedes S600
I disassembled the pump and removed the pistons and springs from the high/suspension side. There is a sleeve bearing that the pump shaft rides on so I am plugging the discharge and filling it with oil for a "bath" to keep the bearing lubricated but it shouldn't require pressure. Next step tonight is to install it and see how it holds up. The V12 doesn't allow for a quick easy non-ABC pump swap so I'll give this a try, but without the pistons riding on the cam lobes I anticipate a positive outcome.
Old Jan 22, 2020 | 02:41 PM
ctravis595's Avatar
I believe that will work!
Old Jan 22, 2020 | 03:01 PM
  #32
MistaJ504's Avatar
2005 Mercedes S600
I have not adjusted any settings yet and still have to set the ride height, but am going to sort the power steering out first so I can allow for suspension to settle while driving. My AC compressor had crapped out on me so I am replacing that and doing all this at one time. I installed front and rear sway bars and believe the spring rates from Ceika for comfort were 14k front and 10k rear. In the future I plan to install a killer chiller type setup so the AC is temporary and hoses will be removed again to tee off the high and low pressure sides.
Old Jan 22, 2020 | 05:26 PM
  #33
Salazar64's Avatar
2003 SL500 R230
2003 SL500 Coilover conversion
I decided to used Silvers Custom coilovers ($1100) they are totally adjustable instead of the Strutmaster kit. Also installed 2003 Ml55 AMG powersteering pump ($50.00). I also to took my car to the dealership to remove the code error (2 hours @ $186 per hour) Honestly I don't think it take this long. I included the thread on how to this. No chip/module needed I think Strutmaster wanted $400.00. I feel it was better to code it out. The car is riding really well!! [
QUOTE=MistaJ504;7960290]I disassembled the pump and removed the pistons and springs from the high/suspension side. There is a sleeve bearing that the pump shaft rides on so I am plugging the discharge and filling it with oil for a "bath" to keep the bearing lubricated but it shouldn't require pressure. Next step tonight is to install it and see how it holds up. The V12 doesn't allow for a quick easy non-ABC pump swap so I'll give this a try, but without the pistons riding on the cam lobes I anticipate a positive outcome.[/QUOTE]
Old Jan 22, 2020 | 05:38 PM
  #34
MistaJ504's Avatar
2005 Mercedes S600
Coding out the fault would be awesome. Your power steering pump was probably a near straight swap being a V8 vehicle, unfortunately mine isn't quite that easy.
Old Jan 23, 2020 | 05:58 AM
  #35
pmercury's Avatar
member
CL
never really worked out with Xentry to get rid of it without the module
I never worked more on it as I got the module years ago
but it should be possible with Vediamo
__________________________________________________ ______________________________
There are many versions and choices for DAS/Xentry Diagnostics for MB.
Ensure you have the right information before getting one. There is too much misleading info.
I’m a forum member and programmer who’s learned the hard way. PM me if you have any questions.
Old Jan 23, 2020 | 10:05 AM
  #36
MistaJ504's Avatar
2005 Mercedes S600
I've lurked a long time and never seen a successful attempt at coding out the abc fault.
Old Feb 13, 2020 | 10:32 AM
  #37
MistaJ504's Avatar
2005 Mercedes S600
No fault with coilover conversion
No faults with new coilovers after I disconnected the entire ABC controller located in the driver side fuse box near brake booster. Only driver alert I receive is for the tpms sensors that need replaced. No red and no blue alert that needs to be cleared. Gone completely.
Old Feb 13, 2020 | 01:32 PM
  #38
pmercury's Avatar
member
CL
great !
Old Feb 13, 2020 | 02:28 PM
  #39
MistaJ504's Avatar
2005 Mercedes S600
I'm just wondering if it has always been that simple all along or if this/my car is just a special case? I've seen others talk about still having the white, or whatever color it is, error message to clear with the dash button even after disconnect of the ABC controller. Perhaps the trick was to remove all of the connections?
Old Feb 13, 2020 | 02:30 PM
  #40
MistaJ504's Avatar
2005 Mercedes S600
At some point I plan on doing a quick write up about my Ceika coilover conversion adventure, but I want to solve all my alignment/camber issues due to my lowered ride height before hand.
Old Apr 12, 2020 | 03:42 PM
  #41
BoxxMann's Avatar
02 CL500 | 06 E350 4M
Time to bring this back again!
I'm looking specifically for the part number of that bracket @smartadze indicated in his posts up there ^ I can call MB this week and get it, of course, but if anyone knows it, it will help me. I want to purchase a reman or new power steering pump and those don't include the bracket, sadly
I'm pulling my ABC pump to replace with a W220 PS pump. All I need to know is that part! Any help is appreciated!
Boxx
PS - MB Parts Miami says the pump will fit 5.8l V12's from 01-06
https://www.mbpartsworld.com/oem-par...bC12OC1nYXM%3D
Look at the bottom of the page for "fitments"
Old Apr 12, 2020 | 10:53 PM
  #42
Salazar64's Avatar
2003 SL500 R230
I used the PS pump from a 2003 ML65 AMG new order it from Amazon for my SL500 R230. I also ended up removing the fuses for the ABC red error code. Still gives white code but I just hit reset and goes away. I saw that if I remove ABC module this will go away also.
Old Apr 12, 2020 | 11:13 PM
  #43
MistaJ504's Avatar
2005 Mercedes S600
I disconnected all connections going to the abc control module in driver side firewall fuse panel and I do not have any error codes or dash faults. No need to push the button to clear it every time I start the vehicle.
Old Apr 22, 2020 | 10:48 PM
  #44
Sportunage's Avatar
2005 W215 CL55 AMG
Originally Posted by capn_shawn
Just replaced my ABC tandem pump with a $79 W220 power steering pump from EBay and everything fit perfect.
Search for used part number 0024668601
Careful if you buy a new one, as it might not come with a reservoir or triangle bracket.
The high pressure steering hose needs to be about 4" longer, but I believe that loosening the first bracket down on the rack will give me that length... I'll know later tonight.
I also have a brand-new, never-installed, complete set of Strutmaster coil-overs that I will sell for $400 + shipping (probably about $110 to lower 48) to anyone on this forum. This kit consist of all four W215 coilover shocks, with 4 ABC plugs and brass caps. If you are just doing an ABC pump recirculation, this is all you will need and it is 1/2 the price of buying it directly from them. This kit does not include the light module. Just message me.
just installed W220 power steering pump and I’m not sure if I understand where I should mount the hose that will be coming from the bung on the reservoir. I’m removing everything ABC related. I’ve been searching the forums for a few days now and there’s not much detail on the fluid circuit for the W220 non-ABC power steering pump mod (I have a CL55 by the way. Going yellowspeed). All of the threads seemed to get off track with people saying that you should keep the ABC or making suggestions on how to route fluid and keep the tandem pump. Any advice would be greatly appreciated. (PS. Just quoted the post above because it has an image of the pump and reservoir and shows the bung on the reservoir that I’m referring to).
Old Apr 22, 2020 | 11:32 PM
  #45
MistaJ504's Avatar
2005 Mercedes S600
It seems you are asking about the return line. This would be the return from your power steering circuit. The ABC reservoir has 2 separate areas. The upper is for suspension and the lower is the power steering. The hose that connected to the lower reservoir is the hose that you would connect to your new resorvoir. I used hose clamps and 3/4 hose and 3/4 barbed fittings where needed.
Old Apr 22, 2020 | 11:53 PM
  #46
ctravis595's Avatar
You can search my threads on my matter, using my username
Old Apr 24, 2020 | 11:44 AM
  #47
Sportunage's Avatar
2005 W215 CL55 AMG
Thanks Ctravis, MistaJ for the explanations and direction. LLcoolbenz went above and beyond by going out to his car so that he could send me a picture of how it’s routed. I’ve been part of many forums with some of my past and present vehicles (Audi,MR2,Porsche). I’ve only been an AMG owner for about a year or so. Gotta say, you got a good group of members on here. Thanks again! Almost got everything ABC out! One of the most satisfying jobs pulling all that ABC stuff off the car. I’m sorry but this system is ridiculously over engineered which is not a bad thing. But to be over engineered AND unreliable... Can’t wait to be done with it! And yes I’ve spent a few thousand just making sure the system was maintained.
Old May 2, 2020 | 12:24 AM
  #48
ctravis595's Avatar
I thought the same thing at first, then a day or so later I noticed I was indeed getting the white, resettable “abc warning “ message on the dash. I believe if removing the computer alone has solved your issue, your car may ironically be “suffering” some sort of electrical fault.
I put suffering in quotes because obviously a lack of an annoying abc warning message is not a real problem!
I think besides the first to do a coilover swap on these cars, I was first to try removing the abc fuses and try removing the abc computer, both methods had varying degrees of success. But not complete success. It’s hard to consider $400 or so, worth it to remove one error message, especially with strutmasters customer service. Hard to want to give them more money despite arguably having the only acceptable coilover kit for these cars
Old May 2, 2020 | 04:10 AM
  #49
pmercury's Avatar
member
CL
https://mbworld.org/forums/cl-class-...x-project.html
Old May 26, 2020 | 05:03 PM
  #50
Braydensdad42's Avatar
2003 SL55
Still have the coilovers?
