CL-Class (W215) 2000-2006: CL 500, CL 600
Aftermarket Radio OEM Fiber amp won't turn on
Old Jan 10, 2018 | 07:13 AM
pmercury's Avatar
member
CL
Exclamation Aftermarket Radio OEM Fiber amp won't turn on
Hi
Anyone would know how to get the OEM fiber optic amp to turn on with wiring
I have the aftermarket radio working fine
fiber optic decoder is on and red fiber blinking
but from the OEM orange fiber no light at all when I turn the key
any experience here ?
Old Jan 10, 2018 | 07:15 AM
pmercury's Avatar
member
CL
this plug is connected nowhere
is this to amp ?
Old Jan 10, 2018 | 09:02 AM
renault12ts's Avatar
W215 CL500 2005
Sorry, I can't help, I ditched the FO.
Old Jan 10, 2018 | 09:30 AM
pmercury's Avatar
member
CL
amp works
I tested it with the old command
and it doesn't require that plug
problem is the dam fiber optic decoder
my plug doesn't fit
even oem fiber doesn't fit in the holes
Old Jan 10, 2018 | 09:40 AM
W215 CL500 2005
Yours isn't MOST. You have D2B.
http://www.mercupgrades.com/Mercedes...article-7.html
Old Jan 10, 2018 | 11:31 AM
pmercury's Avatar
member
CL
can you show me what box I should get ?
Old Jan 10, 2018 | 11:42 AM
pmercury's Avatar
member
CL
seems impossible
I will have to change the amp
https://mbworld.org/forums/c-class-w...onversion.html
Old Jan 10, 2018 | 02:40 PM
pmercury's Avatar
member
CL
done with the stock amp
I just bought a amp
http://www.pasmag.com/car-audio/buye...1200-amplifier
Old Jan 10, 2018 | 02:41 PM
pmercury's Avatar
member
CL
anyone knows where I can hook the DVB tv box to the stock tv antenna ? is that in the trunk or is the oem tv tuner in the radio ?
should be two antennas 2 wires
Old Jan 11, 2018 | 03:39 AM
W215 CL500 2005
I just bought a amp
So, you are doing away with the FO. All connections are in the boot so you will have to run cable from the HU to the boot to connect the amp etc. This is my write up|:
http://forums.mercedesclub.org.uk/in...a-w215.158802/
Old Jan 11, 2018 | 04:55 AM
pmercury's Avatar
member
CL
So, you are doing away with the FO. All connections are in the boot so you will have to run cable from the HU to the boot to connect the amp etc. This is my write up :
removing all OEM amp
rca from radio to trunk
trunk has all speaker wires
wire them to new amp
connect acc power so amp turns on and off with radio
done
Old Jan 11, 2018 | 06:09 AM
W215 CL500 2005
done
Yes.
Old Jan 11, 2018 | 12:18 PM
biker349's Avatar
cl600
Yes.
good info. thanks
