CL-Class (W215) 2000-2006: CL 500, CL 600
Harsh ride and car move to the right
Old May 13, 2018 | 12:06 PM
Zaid Alobaidi's Avatar
cl500,c300,c240,e320
Hello I have cl500 2002 with 145,000 km my car ride not smoth I changed ball joints and lower arm both side , I don’t have any noises
tires and rims I have amg 19 for glk 2013 , also car pulls to the right when hitting a bump what’s the reason ? i’m Really confused is it because this car have strutmaster kit coil over?? Or something else need to be replace , or maybe the rims please guys need an advice thank you
Old May 14, 2018 | 04:12 PM
pmercury's Avatar
member
CL
you probably broke of inside from arms
so your camber moves now
here is how it works
if you broke of the inside of your arms because you did not use a manual you can trash all of them
not possible to repair
if not, just get yourself a alignment in a garage
2 arms each side have these adjustments
2 sorts of bolts possible
Old May 15, 2018 | 04:22 AM
pmercury's Avatar
member
CL
Lucky you
Just about swapping 2 pairs for testing new mods
so here a broken of example:
had that in stock
now here a new one:
now here a Camber/Caster Bolt
and a NON-Camber/Caster Bolt
if you don't 100% hold the camber/caster version bolt when tightening, YOU BREAK OFF the bits in arm
and here a pair of S600 (for sway bar MOD)
the other two alignment arms
and 1 OEM non sway bar W215 ABC version
they all have these ajustments
so you see what you probably messed up
Old May 15, 2018 | 04:29 AM
pmercury's Avatar
member
CL
NOTE: the S600 non ABC version unfortunately has the lower suspension mount more outside. that causes more stress on that supporting joint and gets used earlier
you can not use a camber/caster version bolt to ajust that as you will end up with tires in V position
and you also loose a 1 or 2 kg on the suspension
so you front 12kg spring goes to 10-11 but don't worry, it works fine
Old May 16, 2018 | 01:01 AM
You are right that’s why I’ Heard knock when I was reverse and braked I thought it’s rooters , going to open them soon
Old May 16, 2018 | 01:21 AM
I changed 2 alignment arms and 2 ball joint only i didn’t change control arm only ball joint, and I remember my bolts NON-Camber/Caster Bolt I put them in the middle however didn’t tighten it that much i’m Goona check them
Old May 16, 2018 | 01:42 AM
pmercury's Avatar
member
CL
no too bad news
you undertand that if to tighten well, they rotate and destroy the inside keeping the bolt in the middle
you should check all 4 arms make sure the bolt keeps centered
if not you can repair with pieces of pipe like i show in the threat I just updated
https://mbworld.org/forums/cl-class-...n-bars-dy.html
Old May 16, 2018 | 01:44 AM
in that case tires v position will eat from the side tire I don’t think going to use sway bar mode cuz I’m about to sell car still in good shape 145 km I know going to cry after selling it but I have to do it thank you so much really appreciate it I will check them and update you soon thank you
Old May 16, 2018 | 01:51 AM
I have life time warranty on the alignment arms going to contact them they might replace it for me cuz i paid for the warranty do you thing s430 sway bars going to work on cl500 ? Cuz I found one on the scrap yard ?
Old May 16, 2018 | 02:00 AM
pmercury's Avatar
member
CL
1 ?
you need to replace these by 2
if 2 yes
I recomment front sway bar at least if coilspring conversion
difference is like day/night
Old May 16, 2018 | 02:27 AM
1 ?
if 2 yes
yea for sure 2 control arms and bar goes from left side to the right side , do you think will fit on my car from s430 2002 ?
Old May 16, 2018 | 04:47 AM
pmercury's Avatar
member
CL
if you are talking about a 220170 S430 4matic
answer is NO
Old May 17, 2018 | 04:04 AM
I will take pic and post it when I go next week
Old May 17, 2018 | 04:14 AM
Look like like this with bar attached to that screw in the Middle goes from behind it to the right side
