CL-Class (W215) 2000-2006: CL 500, CL 600
General M275 V12 engine finds
Old May 19, 2018 | 04:04 PM
pmercury's Avatar
member
CL
Just wanted to share this found and what you think
1
here, a V12 engine rebuild specialist removed the V12 with the subframe and swaybar
this is on a S600
so do we need to remove our engine from below too ? hot !
second find,
this pro V12 rebuilder found a vacuum loss problem, very important for turbos too
the place if these seals is somewhere we never look or think of
checking mine tomorrow, I added part numbers
I also found why my engine sometimes smokes, and use more oil too of course
I have been looking for best tools for on-engine
gonna try this and some others
I will post a full threat of course
Old May 22, 2018 | 01:47 PM
Welwynnick's Avatar
2006 S600
In the top picture, I guess that's a Maybach engine, as it doesn't have the W220/215 cast alloy sub-frame.
But in any case, yes, I think if you want to remove the engine, it would be easier to drop it down, with the transmission, on the sub-frame.
Nick
Old May 22, 2018 | 03:06 PM
pmercury's Avatar
member
CL
really yes, me too
Old May 24, 2018 | 08:20 AM
pmercury's Avatar
member
CL
intake manifold leak was correct find
posted here:
https://mbworld.org/forums/cl-class-...ml#post7461548
Old Feb 1, 2024 | 11:20 PM
TMickie's Avatar
2007 S600
I know it's been a TON of years but is there anyway I can the name of the V12 builder you spoke of? I'm in Philadelphia and I can't find anyone to work on it. It has bad valve stem seal gaskets and its drinking oil.
Thanks in advance!
Terry
