Sweet deal on a 2002 cl600 v12...does anyone mod these?
so you can use a lot of the threats for yours
nobody mods the non turbo as far as I know
but you can nitrous it of course, problem is that is already a OEM very hot engine
and you could try to adapt a compressor on the top after you modified the hood
Contrary to popular opinion, the NA cars were very little trouble - much less than the TT's.
However, when they get old they're all walking time bombs, because the engine oil cooler always fails eventually, and you have to take the cylinder heads off to fix it, and that's a big, bad job. In objective terms, it's enough to write the car off.
The S600TT has fewer big problems, though everything suffers from heat, and you get continual problems with suspension and ignition. The S600NA suffers those too, but not as frequently.
Nick
Nick
but also less problems with the GM V8
and less if you buy a DACIA
but if you want more and more HP ........
I'm buying a AC Cobra to fit my new M275
1 year job but fast
