ABC multiple fault codes
start with the level sensors
test the wiring by moving them around engine on
das on at the same ttime so you have live refresh
that should lead to the module driver side, clean plugs
you can't get all these errors with just a hydrolic problem
just my opinion...
You can't get that many real errors all at once. It sounds like a control unit or connector.
My instinct would be to steer away from the control unit as they have the blame far more often than the guilt.
What may be quite likely is a SAM, though I'm not sure if ABC operates via a SAM, it's just that they're often the weak link.
Nick
I put in the Odessey that's in the car in 2014. Since then I've removed the negative cable several times and never noticed any corrosion there, but the positive hasn't been off since I installed the battery. Corrosion wasn't visible, but when I removed the cable, the terminal looked black rather than shiny metallic. Cleaned it and now no problem...
Crap
Well that didn’t take long this time. The dreaded multiple ABC faults are back. This time I’ve double checked the battery, cleaned the terminals, checked the ground and where the main positive cable goes under the passenger foot well, tried a different battery, even tried adding an extra ground cable. Car drives perfect under normal throttle, but as soon as I hit it hard in the lower gears I et a red ABC warning & suspension goes into float mode. If I turn off the car and restart it the red warning is gone and it rides normal. Hook up the SDS & I get this again.
https://mbworld.org/forums/s-class-w...ol-module.html
No fault codes were posted, but the owner states that there was a long list of codes. What ended up happening is that the owner installed the "left rear a-arm sensor" incorrectly stating that it was "It was apx 45 degrees inverted" (I assume the owner is referring to the level sensor in the rear of the car). After he reinstalled correctly all faults were fixed.
Although in your case you might not have an improperly installed sensor, it seems to show that a fault in this sensor can cause more than one fault code just as you are describing. Moreover, your list of fault codes states "Critical vehicle level rear left" which is oddly the same side that the owner had an issue with. Perhaps the sensor can send incorrect signals rather than merely dye out. It would seem to make sense that when you accelerate hard, that sensor is being articulated and then sends an incorrect signal.
Hope this helps.
The low ride height fault has only showed up after the car has sagged/ sat too long and gone down. It goes away when I clear it and doesn't come back unless the car actually sags. All the other codes come back right as soon as I make it throw the red ABC error warning. Always the same set of codes too.
look for something in common with all those sensors, power, ground, etc. Double check both connectors at the module for corrosion. Some of those are on connector 1 of the ABC module and some are on connector 2. All those sensors get a 5vdc power supply, maybe that power is dropping out, only thing that stands out is that the plunger travel sensors also get a 5vdc power supply from the module. There could be more than one voltage regulator in the module to power the different circuits. You have two power supplies to the module, one circuit 30 which is power all the time that feeds from fuse 9 in the LF fuse box and a circuit 87 that is power fed from a relay and then through fuse 46 in the RF fuse box.
If you have an SDS clear out all fault codes and run the car. Pull fuse 9 out and put it right back in simulating circuit 30 dropping out, see what fault codes are stored compared to what you had previously. If it's the same set of codes look further into that circuit, if not then repeat with fuse 46. Circuit 87 relay also powers other modules like ME and ESM, typically when the relay fails you would have a no start condition or other fault codes stored in those modules as well. If this is a problem that occurs once every 6 months it may be difficult to find the problem but if you can replicate the codes every time you drive then it will be much easier. You may just have one sensor that is intermittently shorting and causing a voltage drop at all the other sensors powered off that one chip in the module.
