CL-Class (W215) 2000-2006: CL 500, CL 600
Leaking radiator
Old Jul 6, 2019 | 08:48 AM
Ford9498's Avatar
2005 CL55 AMG and 2005 SLK55 AMG
Leaking radiator
So I need to change out my radiator for cracks at the driver side hose connection. I read that this is a common thing with these radiators. I’m looking at sourcing parts from fcpeuro because of their lifetime warranty. They have a behr and I assume a factory radiator available for sale. Is one better than the other?
I’m also going to change out the upper and lower hoses at the same time. I know they need o rings but is it only on the radiator side? Or at the engine also? I can’t find anything saying that the engine side gets them also.
Shawn
Old Jul 6, 2019 | 12:42 PM
pmercury's Avatar
member
CL
Old Jul 6, 2019 | 04:44 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
i'm dealing with the same thing right now, it's barely starting to leak at the driver side fitting. just waiting for a good day to replace both radiator and a/c condenser as my condenser is damaged. this will be a good day to change out engine coolant, maybe do the seals on the oil filter housing/oil pressure test port on the front of the engine too
Old Jul 6, 2019 | 05:17 PM
Ford9498's Avatar
Pmercury, thank you very much! That’s awesome and exactly what I’ve been looking for! Where did this come from? It would be nice to have access to something like this if it’s in a manual.
Old Jul 6, 2019 | 05:21 PM
Ford9498's Avatar
I’m ordering parts tonight and gonna start tearing it apart tomorrow night. Not sure yet but it doesn’t look like to bad of a job to do. I also need to start tracking down some of the small oil leaks that I have.
Old Jul 6, 2019 | 06:04 PM
Ford9498's Avatar
I’m looking at a 180* thermostat, is that really worth anything? Gonna change out the thermostat while I’m at it.
Old Jul 6, 2019 | 06:37 PM
pmercury's Avatar
member
CL
pm me for info
Old Jul 6, 2019 | 06:38 PM
pmercury's Avatar
member
CL
leave that stock
Old Jul 7, 2019 | 10:42 AM
Ford9498's Avatar
Originally Posted by pmercury
leave that stock
Will do. Pm sent
