CL-Class (W215) 2000-2006: CL 500, CL 600
Hook up iPhone
Old Jul 14, 2019 | 06:07 PM
Ford9498's Avatar
2005 CL55 AMG and 2005 SLK55 AMG
Hook up iPhone
My command unit shows phone on it. How do I know if I have everything in the car to hook up my iPhone with it?
Old Jul 14, 2019 | 06:31 PM
whoover's Avatar
'19 E63S sedan
The phone integration was pretty cumbersome in those days. Originally, you needed a special flip phone that was an option. It fit into a cradle in the console. Then they came out with a BlueTooth adapter that fit into the cradle.
So if your car came equipped with the Mercedes/Motorola flip, you will have the cradle in the center console and only need to get the adapter, which can be found used online. If you don't have the cradle (more likely, unfortunately, as the car-phone option was expensive), you would need to have the phone wiring installed, which is possible but expensive.
Old Jul 15, 2019 | 01:29 AM
Ford9498's Avatar
Thanks. What do people use to hook their phone up to these older cars then?
Old Jul 15, 2019 | 07:32 AM
pmercury's Avatar
member
CL
this https://www.ebay.ca/itm/264316343658
or swap for a android radio
Old Jul 15, 2019 | 07:33 AM
pmercury's Avatar
member
CL
or look here to understand
http://www.xcarlink.co.uk/product.ph...&cat=22&page=1
Old Jul 15, 2019 | 07:37 AM
pmercury's Avatar
member
CL
or this if your car amp is MOST digital (not for D2B versions )
https://www.commandonline.co.uk/Fisc...-Mercedes.html
Old Jul 15, 2019 | 10:52 AM
whoover's Avatar
'19 E63S sedan
Actually, this adapter is for the next generation (W221/W216) which had a more modern integration. It won't work for the W220/W215.
Old Jul 15, 2019 | 10:55 AM
whoover's Avatar
'19 E63S sedan
This is the definitive treatment of this subject:
https://mbworld.org/forums/audio-ele...bluetooth.html
