CL-Class (W215) 2000-2006: CL 500, CL 600
Misfire problem
Old Oct 3, 2019 | 10:53 PM
MartinWake's Avatar
CL55
Misfire problem
Hey guys so my 2002 CL500 started misfiring at high rpms so I changed all the spark plugs I put the very good bosch spark plugs and then it kept misfiring but its only cylinder 3 I then thought it was the coilpack so I replaced it and still misfires when I pass about 4.5k rpm on cylinder 3, I have to admit my air filters are pretty dirty but I dont think thats the problem... if I drive normally up to 4k rpm its fine, and sounds fine once I pass that 4.5k-5k rpm range it shuts off the cylinder and sounds terrible.
I cant figure out what could be the cause next thing I can think of is the injectors or maybe bad compression? does not seem like it to me but who knows if anyone could help me out that would be great thanks! My car has 160k miles
Also I forgot to mention it gives me an error for my catalytic converter, I read some other post and that could be the problem?
Old Oct 4, 2019 | 05:21 AM
optimusprime m1's Avatar
W124 260E
Martin Engine is choked and can not breath i would start with air filter change first .Thees engines ar very complicated if the problem is still with you after filters are changed best to put the car on a star computer at the dealers ..
Old Oct 5, 2019 | 03:00 PM
MartinWake's Avatar
CL55
Yes I will change the filters today, I removed the cats to see if it was that and nope problem is still there :/
Old Oct 6, 2019 | 03:07 AM
MartinWake's Avatar
CL55
Changed the air filters and the problem is still there
Old Oct 6, 2019 | 03:32 AM
SLcharge's Avatar
09 SL500, 03 E320 CDI Wagon
Misfire can be causes by so many things on these engines. Get it hooked up to a Star Diagnostic or get a DAS/Xentry your self, and read out the error codes. Just changing parts, based on guess work, is both exepensive and based on luck.
Old Oct 6, 2019 | 05:21 PM
MartinWake's Avatar
CL55
how do I get it on that star diagnosis?
Old Oct 6, 2019 | 05:50 PM
SLcharge's Avatar
A MB dealer has as STAR tester. If you want to be able to do all electric and software on your car, by your self, I recommend that you get in touch with member @pmercury and let him set you up a DAS/Xentry diagnose system on a dedicated computer. Then you can do exactly the same as an MB dealer can, plus more.
Old Oct 6, 2019 | 07:26 PM
MartinWake's Avatar
CL55
The dealer will destroy me with fees I bought this car for so cheap, and setting up that diagnose system also seems costly, that would just tell me the problem and the problem itself will probably cost quite a lot to fix. I am trying to see what I can do about the problem the best way not cheapest because I plan on keeping this car but I also dont want to take a 160k mile car to the dealer which is gonna name another 100 problems the car probably has.
Old Oct 6, 2019 | 09:32 PM
calgary's Avatar
2001 Mercedes CL500 2006 E350 4-matic
For the cost of those Bosch spark plugs you probably could have had the problem diagnosed by an independent shop or by an authorized MB dealer . If your dealer names another 100 problems, it is still up to you to decide what you want to do about these problems.
Old Oct 7, 2019 | 04:05 AM
SLcharge's Avatar
Less than a 1000 $ for a complete independant system, I think it's worth it, but your call.
The parts you spend by now, could easily have paid for that, i believe.
Old Oct 7, 2019 | 04:28 AM
pmercury's Avatar
member
CL
even less, 700$ if you already have a decent laptop
Old Oct 7, 2019 | 03:00 PM
MrTracy's Avatar
2007 S550 & 2009 CL63 AMG & 2009 BMW 328i Convertible
did you replace your coilpack with a new one or used?
