TPMS not present
I have a 600 and the equipment list according to the vin includes: 475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
However, I do not have the TPMS menu in my dash. A tell tale would be the E63 wheels fitted by the previous owner and I imagine the sensors disappeared with the old rims.
So I guess my question is, what do I do now to re-add the system? Any recommendations on replacement pressure monitors (assuming they are missing)?
Thanks!
then activate in minutes with Xentry
1.
Select Control unit, hit F3
Select Body, hit F3
Select CGW, hit F3
Select Control unit adaptations, hit F3
Select Read coding and change if necessary
Select All codes
Change Tire Pressure Loss Warner status to PRESENT
Press F3 to accept the changes, followed by F3 (Yes) to transfer the coding to the control unit.
Click F2 to back to the CGW section, and then click F1 to go back to Control unit menu.
2.
Select Body
Select Chassis
Select ESP
Select Tire pressure loss warner (activating)
F4 to switch the system on, then press F12 to reactivate it.
Press F2 to accept the changes and then click F1 to back to the Control unit menu.
You may get ESP / BAS errors on the upper MFD - turn the ignition off then on again to clear faults codes.
i don’t have access to Xentry but I think I know a pal that has STAR (same idea?)
Good shout on the valves - they may well be different on these different rims. Maybe it has sensors in there already for the E63 that they came off of and just aren’t compatible. Until I get a tyre off I won’t know.
Can anyone tell me what I should be looking for with sensors? There are so many different types! Or do I have to go to Merscabies and buy new ones?
Thanks! I think the above response will prove very useful to those looking to re-enable their TPMS.
just type your original part in google and find a aftermarket for A0008223306
you need 433 Mhz
then, for the size, you need to check if the size for E63
part should be A0009054100 as reffrence
so if you find that they are the same size and fit you are done
again, you must have the electronic specs from the W215 part
with the size specs from the E63 wheels
As soon as I can pop a tyre bead, I'll have a little look at what's already installed and report back. I will be fitting a full set of new boots (tyres) next year, so this would be a great time for a light refurb and to get the sensors working.
In the mean time, I'm off to the tyre section to discuss the 305s currently mounted to my 10J rims...
Stay tuned!
Will update when all done.
if anyone’s interested, these are the sensors I’ve ordered.
Got the TPMS switched back on through star, fitted the wheels with the aftermarket sensors and all is well. Had to go for a long drive for them to pick up, but they picked up eventually and have been fine since.
£125 for 4x sensors seemed pretty sensible to me.
I’m sure you’ll have no problem moving the OEM units on.
if the antennae are there and they cannot be switched on in DAS/Xentry - you may need to take a look (with a translate app) in Vediamo, but as you may well already know; this is not for the feint-hearted!
I’m in the midst of my 2nd phase of my rebuild which started with rear main seal > rear suspension and am geared up to install a upgraded stereo (Head Unit TBD, 2 Gladen Amps [9 Channels] Audison Bit Nove, Stereo Integrity 6.5” MKiii’s and their 3” Mids in Pods on dash, 6.5 Focals for rear doors, front and rear Cameras) and will be removing the whole interior to spray 4-6mm of Dampener throughout. So while I’m at it I will have the room to lay the required Wiring loom, provided it’s plug-n-play and not a required total replacement! I have Airmatic and understand those E63’s that did come with both Airmatic and TPMS had the TPMS Cable incorporated as part of the 80lbs of Loom originally installed at the factory. My question is whether I can plug into that Loom, as well as the CANBUS and if so, must I install the Antennae in the Wheel Wells up front, or can I get away with the W212 or others that simply require the Receiver with its own antenna and a cable that runs from the Rear up to the front area either under the seat or in the dash to tie into the CANBUS, followed by variant coding?
Has anyone tried to use the simpler OEM setup as mentioned in their W211 E63 or any other earlier models for that matter? If so, that would be quite an eye opener for those of us attempting to cut corners with less parts, so to speak! I mean, if the W212 Reciever can pick up signal from the 4X 433 frequency TPMS Sensors and then convert it to CANBUS signal, that would be easier than installing all those antennae!
My understanding from the EPC is that MY 2007, if so outfitted at the time, could have had either the Beru or the Siemens since both are offered in the EPC? Further, there was both a front and rear Receiver whereby the front operated at 125 freq IIRC? and the Rear at 433, however the sensors were either 315 or 433, so that adds to the confusion. I surmise that by the front receiver operating at 125 transmitting at that freq and the Rear Transmitting at 433 simply delineated between front and rear, even though the front seemingly would pick-up signal from the 315-433 sensors and visa versa for the rear Receiver. Perhaps the later model W212 Receiver with its own antenna is just “smarter” whereby it can both pickup signal from all 4 TPMS and differentiate between front and rear for all 4 sensors and transmit to CANBUS? If so, the plug-in would be the same, right? It certainly would be an easier and less cumbersome install, not that I’m afraid of that. It would just make sense to use less parts for the same result, if possible!
Has anyone else tried retrofitting TPMS in either setup?
On another note, I had no idea they changed the system from antennae per wheel well to a seemingly simpler system. You might need to speak to pmercury about retrifitting kit via Xentry - he will have the answer, or at least a good idea.
Good luck!
