CL-Class (W215) 2000-2006: CL 500, CL 600
Esp-pml+bas 2001 ECU issue
Old Feb 6, 2021 | 11:51 AM
JRAZ305's Avatar
W215
What's up people. So my esp computer is no good I have bought 2 online from Discription it's says 2000 -2005. But the plug pattern are not the same . How can I make this work or should I track down the same ECU that came from the car thanks in advance
Old Feb 6, 2021 | 02:18 PM
BenzNinja's Avatar
Former Vendor
that is not how it works
lookup the right versions on EPC with your vin or buy the same part number only
never trust ebay sellers on that
just return it
Old Feb 6, 2021 | 02:25 PM
JRAZ305's Avatar
W215
just return it
Yep I contacted the seller , started a return and ordered the correct part number
Old Feb 17, 2021 | 09:20 AM
JRAZ305's Avatar
W215
Got the correct Module but same error persist
t QUOTE=JRAZ305;8265057]Yep I contacted the seller , started a return and ordered the correct part number[/QUOTE]
So I ordered the correct Module bas esp fml and still getting esp and bas error code. I don't have access to star at the moment. Looking in to getting a handheld to see if I can further trouble shoot. Any one might have any ideas. With what might be the issue. Going on just the information. I did left to right on the steering wheel, esp light light still there and bas is still coming up. Disconnected the battery changed module and still issue persist .. please help as I'm in the final stages of removing the gremlins. TIA
Old Feb 22, 2021 | 10:46 AM
JRAZ305's Avatar
W215
Bump
Old Apr 3, 2021 | 03:23 PM
JRAZ305's Avatar
W215
So I finally fixed the ABC bad front Valve block . Still having esp bas and abs issues . Ive cleaned all 4 speed sensors .lock to lock the steering wheel . Messed around with the break switch and nada . I changed the ecu for bas plm esp . Drove around with it disconnected noticed transmission wasnt shifting so Ecu seems to function when connected .. just can't figure out what the hell is going on . Still no scanner. Need advice suggestions thanks 👍
Old Nov 17, 2021 | 04:38 PM
JRAZ305's Avatar
W215
Update . So problem. Is still there . Got me a autel maxi 808 pm. Issue that is giving is lateral module behind driver seat . Replaced it and issue is still there. I have 3 esp modules. The original off of the car . And 2 replacement. The 2 replacement gave the same error . Except when I went back to.my original bas esp module. The light flickered a couple of times. Scanned it again .and gave error code .sensors can't detect rough bumpy road conditions . But then I cleared it . And now codes refer back to lateral module. Also no communication with bas plm esp module .can bus error .makes.me feel crazy
Old Nov 17, 2021 | 06:21 PM
pmercury's Avatar
member
CL
did you code the modules to fit your car ?
or do you think you just buy modules and put them on the car and all will work ?
Old Nov 17, 2021 | 06:39 PM
JRAZ305's Avatar
W215
Well what about the original module .
