CL-Class (W215) 2000-2006: CL 500, CL 600
Another cl500 power drain
Old Mar 8, 2021 | 09:16 AM
D.militaria's Avatar
Cl500 w215 R320 w251
Hello!
After this winter i have a problem with power drain(over 2A)
I already know that 0.6A comes from the command unit( took out the fuse) and i have located another drain, of over 1.2A that stops after unplugging one of the plugs in the dome lamp( i have marked it in the picture).
Can you please help me, what can cause the drain?
Thank you in advance!
I'm driving cl500 2003
Old Mar 10, 2021 | 06:11 PM
ukcl600's Avatar
C215 600TT
Do the command and some lamps operate as expected when they have their fuses in?
Old Mar 11, 2021 | 02:12 AM
Yes, but after the battery was empty the command was turning on but with no sound, after some time it was normal.
The lights are working normally.
Now after unplugging that plug, i can't use the remote, the dome lamp doesn't work and the PDC doesn't work. After plugging it, everything works fine, but it drains the battery.
Old Mar 12, 2021 | 04:27 AM
BenzNinja's Avatar
Former Vendor
command no sound is the optical ring restarting
most of the time these drains are caused by modules on can network not going to sleep or waking up every x time where they should stay asleep
there are no missing plugs, many plugs can be vacant as they are used on other models or options you don't have
you can only locate a drain after the car is asleep, all doors and windows closed (to not trigger the alarm)
https://mbworld.org/forums/sl-class-...ery-drain.html
Old Mar 20, 2021 | 03:14 AM
You've missunderstood me, the plug is out there and after unplugging it, the drain stops. My question is, what electronic devices are in the dome lamp, because one of them causes the drain. After unplugging i can't close the car from the remote, and rain and light sensor does not work.
Old Mar 20, 2021 | 04:30 AM
BenzNinja's Avatar
Former Vendor
this
to get you the correct part number you need to give me your vin
Old Mar 20, 2021 | 04:58 AM
this
WDBPJ75J03A039013
Old Mar 20, 2021 | 05:36 AM
BenzNinja's Avatar
Former Vendor
price is euro and dealer price not public
Old Mar 20, 2021 | 05:49 AM
Thanks a lot! I will check it.
