M278 - P0016 code
I have a CL550 with the M278 twin turbo engine and got the error P0016 (position crankshaft / camshaft sensor A Bank1).
The car runs good otherwise, but normal engine start take longer than normal (2-3 seconds) Start / Stop works fine and has no start delay.
I have replaced the passenger side camshaft position sensor on from the intake side, but unfortunately that has not changed the code (I deleted it after the switch)
My guess now is that the diagnosed error is really there and that the timing chain may have lengthened. The engine has about 110k mls. New, updated chain tensioners and check valves for the oil supply are were installed.
My other assumption is the crankshaft sensor, but AFAIK the signal used by all camshaft sensors and then should show all 4 error codes related to cam/crank correlation (p0016-20), right? Since the sensor is quite cheap, I would swap it just as a test.
Do you have any experience with this issue?
Thanks for the help,
Alex
Alex
It turned out that all 4 cam adjusters were shot. In particular they were showing significant wear in the area of the locking barrel (you have to disassemble then to check that. Worst offender was the intake adjuster of the passenger side. When one adjuster is worn, the likelihood that the others are also damaged is very high. (mine had 200k km on the clock)
I also switched out both secondary chains. I expected more stretch there, but both were only about 4mm longer than new.
Its all doable with the engine in the car. Get all the WIS docs and its not a problem.
Good luck Alex
Alex
Good luck Alex
What we did was a test of each adjuster to see if its in the right range of adjustment. One of them was out of range, although the mechanical marks lined up.
We then startet to play around with a filed down cam sensor and moved that left and right in the bore to see in which direction the offset was. This way we were able to pinpoint that it was off one tooth and corrected that.
P0016 is only triggered when there is truly an error in the cam adjusters.
I have new adjusters and tensioners installed but I’ve read that if you update the chain you have to buy new adjusters and tensioners because the new chains have different links and are not compatible. Maybe I can find the older style chain to prevent replacing the new adjusters I just installed.
These newer cars and their respective engines are junk.They will end up totaled soon when one of many repairs will supersede their value.
Good luck Alex
I wonder what is the way to find out which phaser is out of shape without removing it.
I replaced chain tensioners and check valves, but still got the p0016 code and long cranking.
