Lurching at 9mph - Faulty CPS?
I brought the car to the dealership a month ago for the issue. They changed the transmission fluid and said the car runs fine. I drove it home, and once I started it the next morning, same thing. Lurching at 9mph!
Any thoughts on what this could be would be really appreciated! It's getting quite frustrating driving the car with the constant lurching
Just had a thought. You must run the trans in Sport (as do I). Try running it in Comfort and see if it still happens. I believe Comfort starts the car in second gear vs Sport which starts in first.
Let us know.
Michael
I know I should just accept it, but its just so weird that this didn't used to happen, and has been getting progressively worse over the past year.
~BTW '07 Brabus CL600 is such a cool car!
Thanks for the compliment. Yeah, it's cool, but a bit scary. Hit it about 3/4 throttle on a freeway on-ramp. By the time I cleared the on-ramp and was actually on the freeway I saw 145. The limiter is set to 211.
If I was still 26, this thing would be a hoot, but I'm 76, so my reflexes are on borrowed time...
Regards,
Michael
I also found another post of someone with a 722.6 with a similar issue: "Stored DTC of P2108 - The internal electrical check of component Y3/6y2 (shift pressure control solenoid valve) has failed. Since it was electrical in nature, I removed the valve body and replaced the conductor plate and tested the solenoids."
Not sure if these trans issues cited above are related to my issue, but since the symptoms are pretty similar, I wanted to add them to the differential.
