CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Will 275's fit on the rear of the CL55 like the CL65?
Old Aug 28, 2006 | 05:27 PM
Bux's Avatar
Bux
G
with no rubbing etc ...thanks (putting on the 19" 65 rims on the 55)
Old Aug 28, 2006 | 05:31 PM
Chas Jr's Avatar
AMG GTS
No,it will rub..
Old Aug 28, 2006 | 06:31 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Yes they will, I run them on a w220 which has less room.. Check the CL threads.. I know people who run 20's with a 275 rear... all day long.
Old Aug 28, 2006 | 07:33 PM
j.edwards's Avatar
'03 CL55 '03 G500
I'm running 275/35ZR19 PS 2's installed by Brabus on mine. The fenders need to be rolled. They do not rub.
Old Aug 29, 2006 | 12:39 AM
Bux's Avatar
Bux
G
so should just get 265...
Old Aug 29, 2006 | 12:24 PM
Chas Jr's Avatar
AMG GTS
Exactly, get the 265 the others rub..
Old Aug 29, 2006 | 01:22 PM
rogers3's Avatar
ok fella mb members I would like to go 18front/19rear on my 02CL500. Can someone post the perfect size to go without any rubbing?
Old Aug 29, 2006 | 02:37 PM
mclarenm8d's Avatar
2003 CL55 Kompressor Horizon Blue Metallic
Bux, don't give up on the 275's ... you may find that your fenders have already been "rolled". Gee, I wonder who would have done that ??
My recommendation is that you try the CL65 rims with a "lower-grade" 275 first. That way, if you do find that you have rubbing you've invested in a cheaper 275 and then you can go with a high-grade 265 if need be.
Given all the naysayers, I would have almost given up on my plans to fill the cavernous space left over from my 275's (granted on 18's with a 2003) with 295's.
