Hooking up
The ESP is on and I haven't given it full throttle off the line, but even today in a demo run with a friend in the car, there was so much wheelspin that it went a little sideways before it got going. It's great for theatrics, but I'm thinking the factory Yoko's are just not capable of handling the torque. Have any of you experienced this? I mean the wheelspin, not the hooking up with the blonde on SoBe.
Have several colleagues w/CL63 030 w/Contis (who've each owned many 55/600/65 in past) who relay similar feedback re: CL63 tq/trac balance....
But one of these guys just traded-in his CL63 030 for another new CL63 030....this copy has Yokos....will get his feedback....had heard AMG specifically calibrated these Yokos vs AMG CL chassis.....so had hoped Yokos would be an improvement.....
BTW, presume you have correct tire P's set, etc?
Part of why both of us passed on getting '08 CL65 is its poor real-world traction; your descrip of your CL63's trac sounded like trac of my previous '07 SL65......find that I drive faster/accel more aggressively in CL63 than in 65 simply b/c have far more confidence in CL63's trac/stability on uneven and/or wet pavement.....
Another thought....is it poss that Yokos take a bit longer to warm up/achieve trac than do Contis? (I typically wait about 7-10mins post-start-up to allow fluids and tires to warm up sufficiently before any vigorous accel)
For me it has been finding the balance with my right foot of feeding in the right amount of throttle smoothly. I spend a fair amount of time on road courses where this is critical, and with our car's amount of torque, this is even more so. It just takes practice! I guess things could be worse.
btw...you might want to be going slower to pick up the blond!
Here is something to try I am interested in.
In manual in 2nd gear drive at 4000RPM and then mash the throttle. With traction control on I get a big jerk as traction control jumps in aggrssively and then the car accelerates as normal - like a beast. Try the same with traction control off. I seem to get little spin, just the slightest chirp. My feeling is the traction control is too agressive.
The fact that you are spining so uncontrolled with tration control on seems odd.
I didn't mean to imply that the wheelspin I got was uncontrolled. It seems to me that the traction control actually allows some wheelspin before stepping in and decreasing the power. I'm beginning to think it's been dialed in on purpose to prevent the car from actually becoming dead off the line like when one tries to launch in the wet. My observations are admittedly limited, as most of the time I drive very gently, actually going up the gears in automatic mode rather quickly. When I lay into the throttle a bit, the car actually holds the lower gears a bit longer, as though it were anticipating more spirited driving and remaining ready for more. My car has a little over 1000 miles on the clock, so I'm NOT one to make deep and profound comments about it. I enjoy the ability to really smoke most cars on the road, but I exercise restraint. On occasion, though, the testosterone takes over and I allow myself a bit of tire smoke
