CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
burn notice
Old Feb 2, 2009 | 04:25 PM
ieb's Avatar
ieb
CL63 030 Blk/Blk
burn notice
burn notice
The attached MB “star bulletin” relates to high oil consumption for the 63 (engine 156). They say that 1.35 quart/1000 mi is acceptable.
I’m not technical but it looks like CYA to me and I’d appreciate any feed back about if this is really normal for a perfect engine. I have a 997S with 10000 miles that has not burned any oil.
BTW, did you get the title – burn notice – like the TV show. HA HA HA. I’m so clever; I don’t even know how I can live with myself.
File Type: pdf
Old Feb 5, 2009 | 06:04 PM
SL2003driver's Avatar
CLS63, GLK350
CYA bulletin It's for the Mondays after the master German Tech that builds the engine comes back from the weekend beer drinking contest
Old Feb 6, 2009 | 06:45 AM
ieb's Avatar
ieb
CL63 030 Blk/Blk
Never thought that I would driving around with a case of oil in the trunk. Last time that happened I was drivng a Rambler!
Old Feb 6, 2009 | 09:10 AM
WSH's Avatar
WSH
2010 CL65
Suspect it's CYA....esp in era of falling sales vols and profit margins, any mfr wants to control warranty repair costs (often a profit ctr for dealers)
In my expce, any perf motor (esp turbos) from AMG, F or P has variable rates of oil burn, esp in first ~3K mis....mechanics don't seem to understand variances...so need for mfr to place wide parameters on "normal" to avoid lots of unnecessary warranty expense
Oil burn is much like squeaking w/perf brakes, which Big 3 (AMG, F and P) occasionally suffer...again, have never been convinced mechanics have a logical explanation (or solution) for this random issue
Have had dozens of new AMG/F/P over past 10yrs...can't recall any w/material oil burn (except one 996TTS) or any w/squeaky brakes (except one 996TTS and one 997TT, both w/PCCBs)
Old Feb 6, 2009 | 09:18 AM
CLS63, GLK350
Not much different then owning a 2 cycle engine where you have to mix oil with the gas. The only difference is every gas fill up you add the oil not to the gas but to the engine
Old Feb 6, 2009 | 10:35 AM
ieb's Avatar
ieb
CL63 030 Blk/Blk
That’s my problem; I’ve been putting it into the wrong orifice.
Old Feb 7, 2009 | 07:14 PM
CLS63, GLK350
Just think by using a quart every 1K miles you would never need to change oil
Old Feb 7, 2009 | 11:08 PM
99blkmax's Avatar
5spd 99 maxima
Just a tid bit but the dealership my friend works at was changing your motor if it burned oil. now they are rebuilding them cause it was to costly.
Old Feb 8, 2009 | 12:55 AM
HIGH-VELOCITY's Avatar
CL55
Unhappy
It seems as if every automaker has bought into various degrees of planned obsolesence. That is just sad they think that level of consumption is okay.
