Few Bi-Turbo Questions
I have a few questions though. I have done as much research as possible and learned insane amounts of info about these cars in the last 2 days. There are only a few things that I couldn't find.
1. Is the 5.5L 600 V12 Bi-turbo engine the same in the 03'-06' cars as it is to the new body style 07'+? The same question goes to the 6.0 65AMG V12 Bi-Turbo engine?
2. What are the differences in the 600 and 65 engines? Obviously the engine size, but is there any list i could find? I think the 65's have a bigger heat exchanger in front end. I also know the part numbers of all the turbos are different.
1. The engines are structurally the same from 03'-09' for both the 600 and 65 models, respectively. The 07-09 have an updated Bosch ECU. The 07-09 could have potentially more power available as they appear to have significantly larger frontal intake area through the upper and lower grilles. Performance wise this probably would not offset the additional weight gained by the W221 and W216 platforms.
2. I heard somewhere that the compressor wheels on the turbos are different. The I/C H/E is much larger on the 65.
Tom
Tom
Tom
Tom
Tom
Tom
If the 65 really has a different crank, it would confirm the marketing literature that claims it's strengthened. Thus it would be great to know for sure. Similarly, different wrist pins imply different rods, which would also be done for strength as the stock parts theoretically could have been reused. Same with the bearings, since the journal sizes would seem to be the same.
All told, it's an impressive list of mods to increase power output and do it reliably.
2750300101 $3920.00 S65 crank
They are different!
I can get any part number and price for any year MB in a heartbeat! Let me know if I should look at anything else.
What do you mean " higher output " for the pistons ? I'm a lil lost.
I was under the impression that the bigger diameter would compliment the larger bore which results in the higher output ( meaning displacement ) ... Am I wrong in this understanding ? Thanks
Boost is one, but some of the other mods I mentioned also contribute. Others are to strenghten the engine so the extra output doesn't tear it apart. The pistons are in all three categories. They have a larger diameter to match the increased bore to increase displacement. They have a different shape, along with the combustion chambers' modified shape for more optimal combustion. And they are made of a stronger alloy, have larger wrist pins and cooled by a better oil spray system for robustness.
I have never compared the pistons side-by-side, so I'm only going by the literature but the phenomenal increase in inherent torque is evidence of a redesigned engine, not simply an increase in bore from 3.23 to 3.25 inches.
I have another question. Do the 12cyl. turbo cars have BOV's or pop of valves? I'm not looking to change mine to some ricey crap valve or anything that makes noise for that matter, but I'm curious as to weather these cars have some or not and where they would be located.
I bought my S600 in March last year, it's a superb car but I bought it privately
without warranty, I have spent nearly 10K so far on faults and at the moment
it may need a new abc pump.
http://en.wikipedia.org/wiki/Blowoff_valve .
Did yours make the pooting sound of a true BOV?
https://mbworld.org/forums/cl55-amg-...-warranty.html
V12Godspeed, I'm not sure I got what you said clearly. When you said you made and installed the custom intakes and removed the air boxes, did you also say that it did NOT make any performance difference? Did you have 2 mini air filters on each bank like the VRP setup or was there only one? I know you were selling your custom intake a little while ago. Do you still have any pics of it?
Thanks for all the info!
John
I don't think it sounds too bad. Definately not a ricer BOV sound. There is no BOV on the car.
John
Re-reading your statement...it might mean that they will not offer the MB extended warranty after the factory warranty expires. Which I would think it would be similar here (except for CPO cars). I would imagine that as long as you are within the factory coverage (and you are the original owner) they will offer you the warranty.
Tom
