Lowering the CL55
Cheers
The part runs approx $2000.00 uninstalled.
Thats actually not as bad as I thought it would be. I'm guessing installation would be very costly. Which companies do this? And has anyone on the board actually done it? I wonder if there are any cons besides the price. I would be interested in doing this just because I have realized that changing the rims to 20's will compromise the ride much more than "choosing" when to compromise the ride a little bit when electronically lowering the car.
Also was told that the supercharger upgrade will be available by the end of March.
1 1/2" may be a bit much, but I do know that lowering the car will improve the handling. I live in the mountains with all sorts of twisty and curvy roads... So I would greatly benefit from this. My concerns are: Does this Module interfere with the cars inboard systems, such as the ABC and the car's Leveling system.
No... Everything will still work as OEM, however at the lowest ABC setting, the vehicle will be 1 to 1.5 inchesd lower due to the Kleemann module.
I wish I could see the car lowered that level. I think it would look really nice aesthetically speaking.
The consensus is that the kleemann & lorinser lowering modules are UNPROVEN and EXPENSIVE. I have YET to meet any objective person that has lowered their car with those methods.
RBTech and The Wheel Supply lowering method offers the most flexibility. I lowered my S class by 1.5" in the front and 1" in the rear.
The picture below is another car lowered by TWS; more aggressive
And then you have this guy, lowered also by TWS; this car is dropped to the damn ground.
The cost? $400-500 out to the door for TWS Lowering Kit or the RB Tech method
I just talked to Kleeman (Colorado) and was told that their ABC Interruptor Module costs 2079.00. It lowers the car initially 1 inch and according to the installer can lower the car another 15 millimeters. So overall, its a 1 1/2 inch drop. Installation should cost somewhere around 150.00. Is a 1 1/2 inch drop worth that?
Yes, install is about 1.5-2 hours of labor, in which we also explain to you how to adjust the height if you desire. Whenever you're ready for it, let me know!
JL88,
Where did we decide that the Kleemann & Lorinser lowering modules are unproven? We have installed both on cars, and both were lowered as specified. Of the two, I prefer Kleemann. Yes, it is more expensive, but this is because it properly lowers the car by telling the computer what to do, and allows the height to be adjusted without changing parts. The other methods trick the computer into thinking it is riding too high, and thus it adjusts.
Thanks,
Ben
I have not met anyone in person that has lowered their car via kleemann or lorinser, nor have I met anyone on message boards.
There is no "proper" way to lower airmatic cars heh. Instead of replacing parts, you add an interrupt module. They are BOTH AFTERMARKET.
In the end, its the consumer's opinion: $400 versus $2000 for the same results.
Did you make it out to the Kleemann meet a few months ago at the Irvine Spectrum? The new w211 E50K was there with the lowering module (as well as countless other goodies
).My invitation stands, let me know if you'd like to come down.
Thanks,
Ben
The result is the car is LOWERED, fully adjustable, while MAINTAINING OEM functions. What other results do you need?
You, Evosport, and your R&D team should look into designing your OWN lowering part. You would make more money per part and per installation. Instead, you're somehow convinced that just because it COSTS $2,000, therefore it must be superior.
Even Lorinser doesn't have the ***** to sell their lowering module for more than $1k. And remember, they're the ones selling their supercharger for $20k
/boggle
https://mbworld.org/forums/showthrea...threadid=28691
"Thats what i like about the RB Tech adjustable height it takes about 2 minutes and a screw driver to turn the car from a Lo-Lo to an SUV. "
To adjust the height for the TWS Lowering Kit, all you need to do is add washers.
So, I ask you again, $2000 or $400 for the same effect?
You know, for us NORMAL people, we don't get free shop hours and parts at cost. I work hard for my money and yes, $1600 does mean something. One word: VALUE.
I was not aware that this voids the warranty?? Is that true?
If MB can program the Euro spec version with a lower ride height, why can't aftermarket companies just duplicate MB's mod?
