CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Inside M275 Engine (V12TT) and everything else...
Old Mar 23, 2009 | 07:32 PM
Oxygen's Avatar
W220 S65 AMG
Arrow Inside M275 Engine (V12TT) and everything else...
I ran across some information about the Mercedes M275 V12 Biturbo engine and wanted to share it with you guys.
This demystified a lot of stuff for me, maybe you guys can pick out some other stuff.
Some of the diagrams are slightly wrong, as they belong to the M285 which is used in the Maybach, it's slightly different - water cooled alternator and 2nd AC compressor.
Pictures are arranged by category.
Also available on in my galleries: http://photo.thegetlucky.com/p749729540
Oxygen's Avatar
W220 S65 AMG
Old Mar 23, 2009 | 07:33 PM
Oxygen's Avatar
W220 S65 AMG
So far I've learned that the turbos are actually liquid cooled... I had no idea.
Old Mar 23, 2009 | 08:06 PM
jeffw666's Avatar
'05 CL65 AMG
Good ****, thanks for posting
Old Mar 24, 2009 | 11:26 AM
Quadcammer's Avatar
96 and 08 911 turbos
Those turbo units are shockingly expensive for what they are.
good post, thanks.
Old Mar 24, 2009 | 11:35 AM
CLK Masters's Avatar
04 CLK 500, 07 GSX-R 750, S 550, 09 Jeep GC
Good post, good pictures.
Old Mar 24, 2009 | 11:40 AM
1badassbenz's Avatar
Mercedes
Thanks for the post OYGEN lots of great info!!!!
Old Mar 24, 2009 | 04:14 PM
Oxygen's Avatar
W220 S65 AMG
Awesome... if figured if lots of people see the internals maybe we can all come up with ideas.
Old Mar 24, 2009 | 05:12 PM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Chris:
Once again...great information!
Tom
Old Mar 24, 2009 | 05:16 PM
Akademiks's Avatar
SL600
Excellent post!
Should be a sticky!
Old Mar 24, 2009 | 05:25 PM
OUTCAST's Avatar
SLK55AMG, SL600
Wow! That's very cool and informative info on the V12 nice post!
Old Mar 24, 2009 | 05:40 PM
taxi driver's Avatar
A190 500E C43 CLK430
Hi Thanks for this lesson , almost gives me a headache trying to figure out
don't you anyone come and say it's only got 3 valves and 1 cam / head!!!!
$$$$OOOO nice and complicated.. Roger
Old Mar 25, 2009 | 12:57 PM
MarkoCL65's Avatar
CL65
Very cool post. Thanks!!
Old Mar 25, 2009 | 01:29 PM
V12Godspeed's Avatar
Your worst nightmare...
Very nice post chris. Very informative.
Old Mar 25, 2009 | 03:22 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Wow where did you get this stuff?
Old Apr 10, 2009 | 12:02 AM
CA_E55's Avatar
05 E55, 07 SL65, 06 S4
These red 'plugs' look like knock sensors - do you have any information confirming this? I read somewhere that combustion ionization is used to optimize timing - I wonder whether the knock sensors are in fact still on our engines?
BTW - many thanks for these pics! awesome eyecandy!!
Old Apr 10, 2009 | 04:25 AM
Thericker's Avatar
V12-Biturbo
Excellent post Oxygen!! thank you for sharing....
Old Apr 10, 2009 | 06:38 AM
DCMETRO22Z's Avatar
E320
+1
Old Apr 17, 2009 | 12:55 AM
DoctorV8's Avatar
2005 CL65
THANKS!
Old Apr 17, 2009 | 01:37 AM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Those are in fact knock sensors, and they are used to help determine ignition timing to prevent preignition. The computer does use Ionic Current Detection for misfire diagnosis, but at full load at high rpms, the computer reverts back to the good old crank sensor for misfire diagnosis. If the crank slows down ever so slightly, it is determined to be a misfire. Also, the OP was slightly misinformed, as the alternator is liquid cooled on all biturbo cars, not just the Maybach. The turbos are liquid cooled, in addition to the oil feeds and returns also, making for some interesting plumbing on the engine. Also, the black plastic piece between the cylinder valley is a vacuum reservoir for the divertor valves and the wastegates, which are all computer controlled by solenoid valves directing the engine vacuum and boost from the manifold.
Nick
Old May 11, 2009 | 12:53 PM
Oxygen's Avatar
W220 S65 AMG
^ Awesome... thanks for the expert input!
Old May 11, 2009 | 01:04 PM
groupB's Avatar
2009 Volkswagen Routan
Wow ... awesome pics. Thanks!!
Old May 11, 2009 | 06:10 PM
Autoscope's Avatar
Former Vendor of MBWorld
E350 Sport & Rs6
Hello! Nice pics....I just posted some pics of the Internals of a current CL at the shop:https://mbworld.org/forums/cl-class-...gine-pics.html
NOT a TT though..
Old May 12, 2009 | 01:36 AM
CA_E55's Avatar
Nick
Thanks for your explanation, very interesting! (for some reason I only saw your reply today..)
BTW, do yo have any explanation why AMG went to a rear oil sump vs. the MB V12TT front sump? Cant be the chassis because they put the these engines in the same models.
Old May 14, 2009 | 05:50 PM
nick 55's Avatar
Oil sumps are determined by the vehicle chassis the engine is installed in. The 220 and 215 are front sump, 230s are rear sump. Same with the 55kompressors, the 211 and 219 are rear sump, and the 220 and 215 are still front sump.
Nick
