cl65/cl600 differeces:trans,engine turbos,rear...
2003 cl600 blk/blk amg sport 30kmiles
renntech ecu/tcu/intake/exhaust/ic pump
extended 2yr warr.
$30K
2005 blk/blk cl65 35kmiles
no ecu tune
no warr
$50k
have the money for either just want to know if you think the 65 is worth an extra $20k
i think i should just drive both
The CL600 is an amazing car. Very quiet and less showy than the CL65, but an amazing amount of torque and power. Blows the CL63 away.
You could not go wrong with either.
extended 2yr warr.
$30K
no ecu tune
no warr
$50k
I would get the AMG CL65 all day over the CL600.. I feel the tuners gross hp numbers are exagerated and AMG may under state thier numbers.. The AMG car will hold better value, be factory fast and has a lot of other performance features over the Cl600. The tranny in the Cl600 may also not be rated or modified to handle the tuners extra HP , as well as the Cl65 car.
The last big fact, you are getting a very limited edition AMG 180K car for 20K more than a 120K car. Two years newer and for a 3K- ish, can get the exteneded warranty of your choice.. It is a no brainer to me.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
extended 2yr warr.
$30K
no ecu tune
no warr
$50k
Part of that $20K difference is because the CL600 is two years older than the CL65. I know the CL600 has an extended warranty, I just wonder if you will run into problems with the mods done.
The CL65 has other differences (assuming it is completely stock). It has the huge AMG big brakes which would cost $6K to fit to the CL600. This could be an advantage for the CL600 if you are looking to save weight/maintenance costs.
With the CL65 you get the AMG 19" split spoke wheels which I personally think look great. Realistically a set of these 4 wheels cost $3K+ for used.
The CL65 comes with AMG seats, door sills and gauges (not really worthwhile to replace).
I believe the RENNtech exhaust is just mufflers so you have the "standard" exhaust going to the mufflers and single tips on each side (which look like the ones on the CL500). In comparison the CL65 has about 1/4" bigger diameter exhaust piping all the way back to its quad tips. Also, I believe that the CL600 has an extra set of resonators. I haven't heard a stock CL600's exhaust next to my CL65...but since you have the RENNtech mufflers I assume it is louder than a CL65's.
The CL65 comes with a much bigger heat exchanger (50% larger) than a stock CL600. It sounds like you may have the RENNtech intercooler upgrade which consists of a smaller supplemental heat exchanger. The RENNtech supplemental heat exchanger + stock heat exchanger do not equal the CL65's stock heat exchanger in volume.
Overall the CL600 weighs about 200lbs lighter than the CL65. So if the RENNtech CL600 is making the same power, it will be faster than the CL65. A RENNtech modified CL65 should be faster than a similarly RENNtech modified CL600, at least in theory. Obviously, the additional costs to modify the CL65 should be factored into the analysis.
I personally take a certain satisfaction in knowing that I own what was ultimately AMG's flagship model, of which less than 200 were imported to the US between 2005 and 2006. But that wasn't a deciding factor for me. I wanted the 6.0L V12 engine. I wanted the huge cross drilled 15.4" front discs with 8 piston calipers. I wanted the 19" split spoke AMG wheels. I really didn't even consider the CL600 because I viewed it (at the time) as more luxury oriented. Had there been a RENNtech modified CL600 cross my path, I would have definitely looked at it. But ultimately I make car decisions based on emotion and not economic "common" sense. I would still go for the CL65.
Tom
Tom
Tom
I have not a thing to add other than if you get a 65 you don't need to mod it (though some do)...with a 600 you'll always know there's something left on the table as regards engine/brakes/exhaust/cooling....600 is a great car but spend extra on the 65
-Rob
-Rob
Larry
Tom
The CL600 is an incredible car, made even more special by Renntech, etc., but it will never be a CL65. The CL65 is a ground up factory developed AMG at the top of the luxury/performance hill as TMC M5 so aptly describes and is really the only choice if price is no object.
It did bother me some so I went back to powerchip. I'm convinced those guys are the best. They recallibrated the ecu and tried to gear up the turbos, but it was clearly maximized. They did three different tunes until it was clear the original was maximized. Its my third car I've taken to them. I definitely recommend them. Nice guys and really know what they're doing. Hell of a difference on the 600. For the 65, it seems like they're already maximized from AMG. It does make it a little more responsive. But if you want more power, need to modify the exhaust and put in a better intercooler. Probably not worth doing it.
Overall, 65 is a far superior car. The 600 is nice. It doesn't have the solidity, feel, suspension nor the power at higher speeds like 65. They're both gorgeous, can't go wrong with either. 63 vs 600 Haven't ever driven ...
Side note, don't get 22inch wheels with 25 profile tires. Doesn't work with this car unless you're on a super smooth track or orange county.
Thanks!
I've always gone by the philosophy that there is no such thing as a good buy on something you don't want. If you want a 65 you probably will not be happy with a 600 even though 99% of us probably will not push a 600 hard enough to make a difference in real daily use.
There are some great reasons to buy a 600 vs a 65 though, and most of them are green. I never considered a 600 because I wanted a 65. Nothing wrong with a 600, just wasn't what I wanted. After all, noone "needs" either of these cars so if you can afford it then buy what you really want.
Roger down under
Roger down under
