CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL65 AMG Cost of..
Old Aug 11, 2009 | 03:13 PM
ZAMBONIAMG's Avatar
CL65 AMG
CL65 AMG Cost of..
I wanted to see if the cost for "labor" and parts is what others have seen at Stealerships.
Ignition Coil Module $1,300
Spark plugs and insulators - $1,350
Appearently these are the two things setting off the "Check Engine" light on the car with 26k miles on it??????
Old Aug 11, 2009 | 04:32 PM
Oxygen's Avatar
W220 S65 AMG
Well I don't think you need new spark plugs?
The ignition module is probably around $900 and $400 sounds fair to replace it considering the amount of work involved.
$1,350 is a little excessive... there are 24 spark and that gets expensive. I don't see a reason for replacing plugs at 26K miles though.
Old Aug 12, 2009 | 02:25 AM
Oxygen's Avatar
W220 S65 AMG
I don't know what the **** they mean by "Spark plugs and insulators" line because on the M275 V12 there are two components - the coil packs and the spark plugs. Please see below:
Old Aug 12, 2009 | 07:44 AM
MarkoCL65's Avatar
CL65
There are insulators that go over spark plugs.
Old Aug 12, 2009 | 08:32 AM
ivanj's Avatar
Yugos only
Emissions System?
Replacement seems premature to me. I would think it would be covered under the MBUSA 50k warranty or the emissions systems warranty.
Could they suggest a cause for this premature replacement? Is there a bulletin on the car concerning this area?
Just some thoughts.
PS
I want to thank Oxygen for his excellent contributions to this Forum.
Old Aug 12, 2009 | 09:31 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
The spark plug replacement is a major PITA. I think it takes a minimum of 6 hours to be able to do because they have to take off a lot of stuff just to get to the area. As mentioned, the 24 plugs are not cheap either.
Tom
Old Aug 12, 2009 | 05:56 PM
ZAMBONIAMG's Avatar
CL65 AMG
Thanks Gentlemen! I appreciate the help on this.
They said they would not guarantee the "check engine" light would go off if the plugs were not changed out. They said it was one of the "codes" that popped up. I just wanted to get the light off as it has come on 2 times in the past 4 weeks like I said....sounds fishy to me but it is a MB dealership and it is not easy to build a $180,000 car with "low cost" maintenence I guess.
I have honestly never had issues with any car like I have with this touchy piece of German Engineering. May be the first and last MB for me.
Old Aug 13, 2009 | 02:38 PM
sprins's Avatar
G55, SLS, smart eq
Originally Posted by TMC M5
The spark plug replacement is a major PITA. I think it takes a minimum of 6 hours to be able to do...
Say WHAT??!!??!? 6 hours for a spark plug replacement? Do they rebuild the engine in the process?
Mental note: stay away from 12 cylinder benzes...
Old Aug 14, 2009 | 12:08 PM
Oxygen's Avatar
W220 S65 AMG
Well all of the fancy stuff needs to be removed... the intercoolers, the plumbing, the ignition modules, etc...
And then you have 24 spark plugs that you need to change!
Old Aug 14, 2009 | 03:12 PM
Vadim @ FD's Avatar
S600TT, R350
ZAMBONIAMG:
Get the SA to give you codes print out.
Better yet go to Auto Zone or any local auto parts stores, most will read out OBDII codes for you for free or nominal fee.
Let us know what they are.
Old Aug 14, 2009 | 11:01 PM
ivanj's Avatar
Yugos only
Reminds me of the 308 Ferrari
A guy I knew bought one of these new whenever they came out I guess back in the 70s.
When he brought it in for a tuneup, they said it would take 12+ hours. When he asked why, they told him it was because they had to take out the back of the interior to get at the spark plugs that were in the front of the engine.
Twas' ever thus....
PS
The NSX is much easier to work on!
