will 305 tires fit on my 03 cl55?
Now on mine, the rears are 10.5 inches wide, exactly splitting the two sizes your wheels MIGHT be. If yours are 10s, 305s would be pushing it, and I am not sure if 11s will fit. I think you will be trail blazing with either size, unless someone else chimes in who has tried it before.
You the man!!
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
What offset are you running on the rears?
Patentmat, I don't know how you do it.... with mine lowered and rolled on 285s, I already rub pretty good (sometimes, especially on crappy freeways at high speeds).... with 305s, I think I would blow a tire
Exotic-metal55 worte:
jicl55 wrote:
They completely changed the demeanor of the car, it's so much more aggressive, without looking wrong, as a matter of fact it looks more right than ever! Super sporty, with an autocross feel.
Now the bad, so far mine have rubbed once at 45 mph down a regular road with a bit of a dip in it. They haven't rubbed on speed bumps or anything like that as I slow way down for them anyway, no rubbing on the highway or in higher speed turns at all. So I now I know to slow for dips as well.
They do stick out past the rear body kit but not past the fender, they're just about even with the fender.
The conclusion is ABSOLUTELY do it!
Looks great!
Stick like glue to the road!
Just curious why you say the CL55 can run a 305 but don't think a CL65 cant? I thought the body was the same. I am trying to fit drag radials on my CL65 and the only 19" DR's I can find are 305's. Hoping I can fit them.
My current wheels are a 38 offset and I get rubbing with stock tires at high speeds now but I just bought new wheels with a 48 and was hoping I could have them widened and run a 305. I'll be test fitting them next weekend and will report what I find.
Im looking for a size that will improve traction but not hurt handling.....
http://acidcow.com/cars/1459-mercede...g-44-pics.html
And I believe yours has a Qauife LSD and was installed in Newburgh? Apology if way off.
Yes, its the right guy, PM sent let me know if you have any other questions. Be sure to confirm the LSD part number it may differ from mine. You may have to get in touch with a Quaife distributor to confirm the part number and fitment.
