CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
WHEEL SPACERS FOR CL 6.3
Old Apr 14, 2010 | 03:16 PM
yaroslav's Avatar
GL550 , CL6.3 AMG
Question WHEEL SPACERS FOR CL 6.3
Where can i buy Wheel Spacers for CL 6.3 and what size do i need?
thanks
Old Apr 14, 2010 | 03:22 PM
yaroslav's Avatar
GL550 , CL6.3 AMG
I have found this site. Which system to choose and which size?
http://www.tomassporttuning.com/scc-spacers.php
Old Apr 16, 2010 | 11:05 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
If you must widen your track go with H & R Spacers, they are the best IMO. You should lower your car first at least 15 mm or it will look ridiculous with the wheels hanging out and massive fender gaps.
If you have stock 19" or 20" wheels, they are ET43 Front and Rear.
The thinnest hubcentric front spacer is 10 mm. Anything over and your wheel
will be sticking out of the fender. Anything less and it will just be a flat disc without a hubcentric flange.The vibration will drive you crazy- you cannot accurately center the Front wheels with the 5 bolts and 1mm off is all it takes to wobble at 100kph+. Rear you can go 10mm or 15mm.
Attached photos of my car lowered 15 mm with 10mm F and 15MM R spacers.
Stock bolts are 45 mm long shaft, 14 thick x 1.5mm thread or "14 x 1.5 x 45" round head so order longer bolts :10mm spacers = 55mm, 15 mm spacers= 60mm. You can get away with all 60mm bolts as the hub thread is through and there is nothing behind so the longer bolts won't hit anything.
Good luck.
Attached Thumbnails WHEEL SPACERS FOR CL 6.3-104appleimg_4018.jpg   WHEEL SPACERS FOR CL 6.3-104appleimg_4019.jpg   WHEEL SPACERS FOR CL 6.3-104appleimg_4021.jpg
Old Apr 17, 2010 | 02:45 AM
yaroslav's Avatar
GL550 , CL6.3 AMG
Thanks a lot man
Do you have any problems with vibration at high speed?
Old Apr 18, 2010 | 05:54 AM
Rafal's Avatar
Thanks a lot man
Not any more, but I did with a 5 mm flat disc front spacer.
It vibrated all the way but it was worst over 100kph.
Now it is as smooth as ever, just make sure your wheels are balanced perfectly or you will never know what is causing the wobble
Old Apr 19, 2010 | 06:28 AM
yaroslav's Avatar
GL550 , CL6.3 AMG
Man i decided to go with VITT WHEELS:
They offer Offset: +40,+42
Which one to choose?
FRONT WHEEL: 20 X 8.5
REAR WHEEL: 20 X 9.5
Their site:
http://www.vitt.jp/Wheel/JUDGE/JUDGE.html
We can order VITT Judge in the following sizes for W216 CL500/550:
2085 et42
2095 et40
Old Apr 19, 2010 | 02:43 PM
yaroslav's Avatar
GL550 , CL6.3 AMG
I think Offset +35 will be fine? right?
Old Apr 21, 2010 | 09:21 AM
Rafal's Avatar
If the wheels come with ET35 it will be fine. If they come with 40 or 42, how are you going to get to 35?
From 40 to 35 will require a 5 mm spacer which will not be hubcentric, as per my previous post.
ET40 wheels and leave it at that, they will still be 3mm more out than stock.
Old May 9, 2010 | 07:24 PM
hyelifeCL's Avatar
CL600, E30 325i Previous ride CL55 2004
Rafal the CL looks very nice!
