paddle shifters
I could be wroung, but the above statement is true for a E55
Hope this helps.
And it does indeed downshift when coming to a stop.
Ron = As long as you don't get stupid with the tranny, you should be fine. Just make sure you change the tranny oil. I do mine every 15K miles, but I'm tuned and I usually drive in Manual mode.
Actually, "S" is known as "Sport Mode" for "Standard Driving" according to the MB Manuals.
One can manually upshift or downshift without worrying too much because the TCU will not allow a shift if it is beyond its safety parameters.
GL
As such, I can only go by what my Owner's Manual says... and it says "Standard" mode.
:shrug:
Get a transmission filter while you're at it, and do it the right way. Drop the pan. This will require a new pan gasket (cheap), as well.
Personally, I stay with MB transmission fluid. That's the only fluid I buy from MB. It's relatively cheap, and MB can't complain if something happens to the tranny and I go after them.
