CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Help
Old Nov 3, 2010 | 04:01 PM
CL55AMGRON's Avatar
2005 CL 55 AMG
Help
Anybody know what type of pastic they used for the front door controls on a 2005 cl55? A clip broke and I want to get a plastic repair kit, but need to know what type of pastic it is.
Old Nov 3, 2010 | 07:29 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
Good Luck.
If I were you, just buy a new one. If you can't affort new plastic, trade the car in.
Old Nov 4, 2010 | 11:05 AM
CL55AMGRON's Avatar
2005 CL 55 AMG
Dumb answer
That has to be the dumbest answer I have got in a very long time.Did you get up on the wrong side of the bed? You must work for the goverment...It's broke don't fix it just buy a new one or get rid of it.The cheapest I found the plastic part was $245 http://U:\M-BENZ CL500 CL600 CL55 MA...62945 PST).mht. I can afford it but for $3 I can get a pastic repair kit if I know the type of Plastic it is. The fix will take about 5min. and a day to dry.However it does mean you have to use tools and your brain i guess that leaves you out. I have been restoring car's for 35 yrs and you always want to use the part that came with the car. I will have this car for a long time .It looks like it just came off the showroom floor.Try not to reply with something witty I don't want you to hurt yourself.
Old Nov 4, 2010 | 11:15 AM
OK55's Avatar
Mercedes E55 AMG (2006), Mercedes 560 SEL (1991)
Have a similar problem on my 06 E55k. Pls let us know what kind of adhesive you use finally. Like you, I intend to keep my beast for quite a while...
Brgds
Old Nov 4, 2010 | 11:20 AM
IngenereAMG's Avatar
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
Depending on how it broke, Super glue can be your friend!
You also may be able to source a used one from a junk yard. I sometimes use these guys...
http://www.partshotlines.com/?phl=se...ch_id=24462522
Old Nov 4, 2010 | 12:04 PM
saintz's Avatar
GL450
eBay is a good source for little parts like that. There's also a guy on here parting a CL600 that might help. https://mbworld.org/forums/cl-class-...000-miles.html
JB Weld and similar epoxies are generally good at repairing plastics. I don't think the bond is as strong as super glue, but it appears less brittle. I would assume if it's your basic black plastic that it's ABS. Look for a code, possibly a recycling code, on it to try to identify exactly. Most epoxies, however, aren't that picky.
Old Nov 4, 2010 | 01:10 PM
CL55AMGRON's Avatar
2005 CL 55 AMG
Thanks guys. I use putty to make a mold of the clip then pour the plastic into the mold..it is most likely abc..but just like to make it as true as i can.
Old Nov 4, 2010 | 01:21 PM
CL55AMGRON's Avatar
2005 CL 55 AMG
great link
Thanks Ingenere amg great link.
I hate that they use plastic for the clips that hold the molding and controls..$100,000 + car you would think that they would use metal. Clip goes and the part just hangs there and looks unfinished.Sorry for the vent. Not a big plastic fan when it come to holding things together. My kids vw had a plastic waterpump head.go figure
