CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Seats Lumbar suport does not work (CL55)
Old Feb 19, 2011 | 03:39 PM
Road Racer's Avatar
'18 AMG GTR, '04 CL55, '04 E55, '03 CLK500, '01 E55,94 E500, '91 190E 2.5-16 EVOII, '86 560SL
Hello all..
I have a '04 CL55 that I bought a couple of months ago.
The car has 70k miles on it, and everything on the cars works very good, the ABC suspension works nice.. When I dont use the car for more than a month or two it lowers a little... But I just started and returns it to its original height... So no problems with that.
The only problems that I have is that the LUMBAR Supports on the seats does not work at all, same with all the functions that includes this feature.
I heard a little "click" when I activated any of the buttons, but nothing happend.
Before taking it to the stealership, I want to ask here if anyone had this problem with your Cl - S models, since the sistem is pretty much the same on all.
Any help or idea will be very much appreciate it.
Old Feb 19, 2011 | 06:56 PM
saintz's Avatar
GL450
If none of those functions work, it's something with the PSE pump which inflates the air bladders in the seat. Does you door soft close work (if you don't fully close the door, it should suck it the rest of the way closed)?
You probably need to reset the PSE pump by pulling the fuse or the battery. After that you'll need to check which functions work. Most likely one function has a leak, and is causing the pump to run too long. This causes it to basically turn that function off to protect the pump (pulling the fuse/battery will reset that, so you can diagnose the issue).
Hope that will get you started. If it turns out to be an issue with the bladder leaking, pull the back off the seat and you'll probably see a hose dangling. Connect it back to the bladder and then zip tie it so it won't pop off again.
Old Feb 19, 2011 | 10:00 PM
zneB-sedecreM's Avatar
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
Which fuse is it, and where is it located?
Thank you
Old Feb 20, 2011 | 01:31 PM
saintz's Avatar
GL450
Under the passenger rear seat, there's a panel that pops out. There should be one yellow fuse in there. Try pulling that and putting it back in.
Old Feb 20, 2011 | 10:18 PM
I removed the yellow fuse today (Actually, I removed a yellow fuse (5) and 2 clear fuses (25) that had a yellow back plug in socket so they looked yellow lol), turned the car on/off to make sure it read everything...and nothing lol. I didn't disconnect the battery, so I have yet try that. I hope it'll work, but I doubt it. It seems too easy haha
The 'PULSE' button lights up red when you click it, but it doesn't do anything, same for both driver and passenger sides. And when I click the lumbar switches, the 'PULSE' button goes off, and I hear the motor in the back of the seats, but they don't do anything. I'm not too handy and I really don't know what to look for behind the seats if anything is wonked up lol. This sucks, I need my *** massaged.
BTW, I have a question, while looking at the rear fuse box underneath the seat, I noticed a few fuse slots were empty and didn't have a fuse in them. Only about 2-3 slots were empty if I remember correctly. Is that okay, or is every slot supposed to be filled?
Thank you
Old Feb 21, 2011 | 12:10 AM
saintz's Avatar
GL450
Pretty sure there should be empty slots. That's normal.
The fuse you need to pull I thought was a 20 amp (yellow or orange). I'll have to check mine.
Old Feb 23, 2011 | 11:31 AM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
be careful w/that cover I broke the clip on that thing and cursed at myself all day afterwards
Old Feb 23, 2011 | 01:44 PM
Hmm, I pulled the orange one too, didn't do it for me. I hear it, it just doesn't work lol.
And yeah, that cover is annoying. I didn't break mine...yet lol
Old Feb 23, 2011 | 01:58 PM
saintz's Avatar
GL450
So when you try to inflate the seat bolsters, does it make noise but doesn't inflate? That would mean the pump is running but you have a leak.
When you set it on pulse, the noise you're hearing is the motor moving the bladder up and down, it's just not inflating.
Do the door and trunk soft close work?
You might need to pull the battery to make sure you get it reset to test fully.
Old Feb 23, 2011 | 03:48 PM
Yes sir, the soft touch doors and trunk all work marvelously lol, its just the damn seats. I will disconnect the battery and let you know what's up. Will I lose my presets for my seat, convenience, and radio settings?
Thank you for the help.
And yes, whenever I press any of the bolster switches around, I hear it clicking or moving (for both seats) and whenever I press up the 'PULSE' buttons, they just light up red for a couple seconds and as soon as you press any of theother seat buttons on the bottom, the light goes off.
Old Feb 24, 2011 | 10:15 AM
saintz's Avatar
GL450
Shouldn't lose any settings when you pull the battery. You'll just need to resync the windows and sunroof (put them up and hold for a second until you hear a faint click).
Good news is your pump and everything works if the door soft close works. Does your passenger seat work? Either a leak or a control module somewhere. Other than opening the back of the seat, which is fairly easy (should be two screws underneath and then it drops down), and looking for a loose hose, I'm not sure what else to check.
Old Feb 27, 2011 | 06:14 PM
I should have listened to you earlier. Pulled the battery, waited 3 minutess, put it back in. Pressed 'PULSE' and my seat started feeling up on me lol
Thanks for your help
