CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 Front rotors alternatives to OEM...
Old Apr 5, 2012 | 11:17 AM
littlehandegan's Avatar
Gelandewagen
Any suggestions to alternatives of the expensive OEM front rotors? For a 2003 CL55. Also need some pads!
Old Apr 5, 2012 | 08:03 PM
m_berman's Avatar
06 CLS55 w/ P030, 05 Jag S Type R, 05 TBird-68 Dodge Charger R/T-440 w/4speed I'm original owner
I got my cls 55 composite 15.2 in dia rotors (P030 perf pak) from:
http://www.rmeuropean.com/
Saved about 30% for genuine MB Rotors. Get Akeenobno Euro Pads--zero dust.
Great company to do business with. You can negotiate a few dollars with them.
Make sure you read the technical stuff before you begin. Some concerns:
1. Caliper bolts are single use bolts-need to get new ones (200 ft lbs of torque kind of tiresome to get off-may need to torque them on a lift for the leverage-I took mine to dealer and had him do it along with a brake flush and reset the computer; less than $150.)
2. AMG-Brembo Hi Performance brake fluid-flush entire system
3. MB Hi Temp Grease for the Pad backer plate.
4. MB HI Temp Wheel Bearing Grease-Repact the front wheel bearing (if more than 75k miles may wish to install new ones)
Old Apr 10, 2012 | 12:46 PM
Gelandewagen
Any other inputs on rotors or pads that work well?
Old Apr 10, 2012 | 12:55 PM
1995E320Cab's Avatar
2003 CL600 2005 745Li
I would send Exotic-metal55 a PM he went thru this and worked out some good options.
Lets us know what you find out.
Old Apr 10, 2012 | 05:14 PM
Gelandewagen
Also how does one tell if you have a 4 pad or 8 pad system up front?
Old Apr 10, 2012 | 06:16 PM
kenpho10's Avatar
2005 cl55 eurocharged flash
I'm in need of both front and tear rotors for my CL also. Let's try and see if we can do a group buy to get better pricing. I can check around.
Old Apr 11, 2012 | 12:30 PM
danlnyc's Avatar
04 CL55 (sold), 2012 CLS550 (sold), 2014 S550 (sold), 2015 ES300H (DAILY)
it's 8 pads total for the front....insane I know lol I was surprised too
Old Apr 19, 2012 | 05:19 PM
Any updates on this ?
Old Apr 19, 2012 | 11:17 PM
Gelandewagen
Never got around to it. Car arrived last night @ 9pm...already installed my new wheels though!
Old Apr 20, 2012 | 05:19 AM
cm60k's Avatar
Why go to expensive Rotors..??, if you have "8-pot front & 4-pot rear", just stick with a cheap ones which is;-
front: "230 421 07 12"
rear: "230 423 16 12"
ZAYED,,
Old Apr 20, 2012 | 05:39 AM
NRL's Avatar
NRL
CL65, FJ80, Sportsmobile 4x4, Model X Plaid
ZAYED,,
I think those work on a Sl65, why not a cl65?
Old Apr 20, 2012 | 06:30 AM
cm60k's Avatar
CL65 uses "220 421 26 12", which is 390mm dia front,, around ($920) each, damn so expensive........
ZAYED,,
Old Apr 20, 2012 | 11:58 AM
NRL's Avatar
NRL
ZAYED,,
Yah, I know..expensive.
Don't know why.
Can we turn our AMG rotors?
Old Apr 22, 2012 | 03:52 AM
_AMG_'s Avatar
C63
Have you tried contacting Evosport?
They sell 2 piece lightweight rotors.
Old Apr 22, 2012 | 04:50 AM
cm60k's Avatar
They’r also expensive ($2450).......
ZAYED,,
