Extra Kick?
Anyone else have this experience?
Since I just recently surpassed my 1,000 mile break in...I have been driving the car a bit and noticed that when you put the pedal all the way down...and then push it a bit harder, you will notice some moe space in which you can push it further. When I did this, the RPM's accelerated to 7.5 and the car took off...
I will try that later today and get back to you. What's the redline on this thing anyways?
As for Red line...there is no official red line mark on my CL55 - which is odd.
You have pressed the "rocket" button. Go and take a closer look behind the gas pedal, you will find a circular button, when you floor it, that button is activated and your car will give you the maximum power/kickdown available. I believe all current MB models have that button.
Doesn't this button also turn the A/C off while it's pressed? To allow maximum power. I think I read that somewhere..probably on this forum.
don't think a button for turning of the AC would be located under the pedal...
Pretty interesting.
I have used that "button" before but never with such an effect like on the CL55. There is a brief pause - RPM's go to almost 7,000 and then it takes off.
I tried it again over the weekend...with the AC on...and yes..it did shut my AC off.
Pretty interesting.
