cl65 downpipe upgrade
i spoke to a very famous fabricator in california and i mentioned that i would like a cat less down pipe for my cl65.. so my point here is maybe if i can stir up enough people who are interested in downpipes for there cl65.. maybe i can get a GROUP BUY going and have it cheaper so we all benifit.. so if people are interested i will be having my downpipes made with in this mouth hopefully ( fingers crossed) i will up load pictures of the build and see if you guys like it
thanks
R.K.
)Cost shouldn't be more than $400-$600 out the door for DP's cat delete alone...
Turbo's & SuperChargers are different in this aspect, maybe why you question it etc.. TurboCharged motors hate back pressure, NON TurboCharged cars need to scavange some of the exhasut gases. Turbos work best when there is a big pressure difference on each side of the Turbo.
The stock cats are really restrictive, DownPipes and a free flowing 3" straight pipe exhaust will allow higher boost. The waste gate can be disconnected or modified by multiple ways you will be able to boost till the car hits fuel cut-off... I've modded my SL600 to hit 700+ rwp 800+ rwtq on oem Turbs (Q16 + mods etc)
Yes, a turbo engine likes to flow and does not like restriction but neither does a supercharged engine. It is all about increasing exhaust flow and keeping your exhaust velocity high. Engines don't like backpressure. Then again, backpressure is not an accurate term and should not be used when talking about exhaust flow or velocity.
Your SL sounds awesome. Speedriven doing the work?
you pick a few hp/tq simply because the ecu is programmed to curb to a particular psi at stock volume of exhaust. bigger exhaust/intake etc all increase power because 17 psi at 2.5" pipe is less than 17 psi at 3" pipe air/ exhaust flow.
btw, some back pressure is good at lower and mid rpms- gives you more tq.
free-er exhaust moves the tq curve of an engine up in the rpm range.
thus usually when you do long tube headers/full exhaust mod you feel the car weaker in the low rpms, about the same midrange and more powerful up top.
I'm in. Let us know the details or PM.
this setup is 3 inch 304 stainless steel all mandrel bent piping. what do you guys think?
I am interested as well...
