How to remove MAP sensor?
Any tips would be greatly appreciated.
I am certainly not a pro at this engine platform, but this is how I did it.
Removed the air boxes and surge tanks.
Remove the metal tube the pokes into the supercharger inlet.
Unplugged the MAP and throttle valve.
Remove the fuel rail and injectors.
Undid the bracket for the oil dip stick tube.
Remove the bolts that hold the supercharger to the cylinder heads.
Remove the belt.
Removed that valve thing that has that U hose on the driver's side.
Then I lifted the rear of the supercharger up enough to access the bolts to the MAP and placed a hunk of silicone hose under it to hold it up.
Swapped the MAP and then put all that stuff back on.
I did replace the gaskets for the surge tanks and the supercharger to cylinder head.
G
I am new here.
I own a cl55 AMG 2003 model
It's asking for a Map Sensor
I have the part but nobody knows
Where it's located !
Can anyone send a photo or clear
Instructions ?
Car has rough idling at 1100k revs
And vibration is felt through the car.
Has new motor and trans mounts.
A major service has been complete.
I wait patiently
Many thanks
Ok I will investigate !
My car is right hand drive
Is it near the passenger side air box ?
By the way
We have the same car !
I will also buy a prop shaft flex disc
Only to to be safe and hopefully
Eliminate the judder.
Hope your ok sir !
Dealer book time is only 1.1 hours so it maybe easier to just go pay $150 bucks in labor. I have my old one that is still good. After I did the map sensor, it turns out there was a vacuum leak so I did it for nothing.
You make it sound easy!
I'm sure to tackle the task !
Will take off the air boxes and have a
Look by the throttle valve.
Do you know if our cars hold a MAF sensor ?
Have done a lot of work to my car
And my next job is complete suspension
Lines with shocks.
Your very kind sir !
You are very knowledgeable
Indeed!
I will tackle this Map sensor job
Hopefully tonight.
If my poor idle still persists
Could well maybe the IAT sensor.
Can you also tell me where it's located ?
I have also been reading about the prop shaft
Flex plate.
What kind of a job is it sir ?
Many thanks once again !
I replaced the MAP and IAT sensor
Have noticed a change in the drive.
Thank you !
However I still have rough idling
My friend has a Snap On computer
We connected to my car
Now it says
"B6/1 camshaft hall sensor signal implausible"
What could this mean ?
Can it be the cause of my rough idle ?
Many thanks
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Thank you for your reply
To all !
I have done the cam sensor
The old one didn't look good
Seemed burnt a little to me.
However my idle problem still remains !
It's like the motor is misfiring slightly
And when I rev to 1000revs in park
The vibration seems to come from the back of the car
I can feel it from the back of drivers seat
Could it be the EGR valves ?
Maybe the Idle Control valve?
Have cleaned the O2 sensors,
They were dirty !
Car has become more responsive !
Well worth doing with brake cleaner and wire brush.
But the idle vibration which is irratic remains
Any clues ?
Many thanks everyone !
Yes engine and transmission mounts
All replaced last few weeks.
Correct me if I'm wrong sir,
But are there 3 engine mounts on this car?
I have done the two mounts by the sides of the motor.
I think I read there maybe a third mount somewhere.
Tomorrow I will replace the diff end flex disc
Might cure the shake when accelerating to 80mph
Or it could be a diff mount?
Also do you know where the idle valve sits ?
Yes I agree!
I must do a compression test
Do you know what the exact figures
Should be ?
My wallet is not very happy with me lately
I must eliminate the idle problem.
Fuel filter is new done last week.
There is hesitation during overtake,
Which shudders the car slightly
I'm quite sure it's coming from the back.
I thought my Catalytics were failing?
The pull is not smooth during overtakes.
Seems as if something is choking the engine
Slightly.
Many thanks again sir !
