CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL 55 trunk wont open!!
Old May 30, 2012 | 12:15 AM
AlexM425's Avatar
CL55 AMG
nothing seems to work, have tired everything to pulling the fuses. Any Ideas??
Old May 30, 2012 | 10:29 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Will it open with the key? Maybe your vacuum pump is not working.
R.K.
Old May 30, 2012 | 11:38 AM
FRQ FLYR's Avatar
05 CL65, Ducati 999R
I had this problem. Service manager told me that a cable broke and had to be replaced.
Note: I have the automatic trunk open/close option
Old Nov 27, 2012 | 09:15 AM
rbreaks's Avatar
'06 CL55 AMG, '08 SL65 AMG, '09 e550 4Matic, '13 Range Rover Sport Autobiography
Had similar problem w/ my cl55. Got it back from the dealer and the trunk wouldn't open remotely. Brought it back to the dealer and they had to replace the actuater (sp?) -- whatever that is. They did it under good will, so I didn't have to pay and supposedly the parts were $2k.
Old Nov 27, 2012 | 01:22 PM
AlexM425's Avatar
CL55 AMG
Do you where the part was located? Because I'm not getting any error codes and it just seems like the truck dose not want to unlatch? You can hear the lock open and close but dose not unlock? So might be the cabel?
Alex.
QUOTE=rbreaks;5446677]Had similar problem w/ my cl55. Got it back from the dealer and the trunk wouldn't open remotely. Brought it back to the dealer and they had to replace the actuater (sp?) -- whatever that is. They did it under good will, so I didn't have to pay and supposedly the parts were $2k.[/QUOTE]
Old Nov 27, 2012 | 01:55 PM
awiner's Avatar
2003 CL55 AMG
Search the forum. Common issues. Usually the pneumatic actuator located behind the trunk-lid lining.
If this is the case, your metal key blade will allow you to unlock and open the trunk.
Old Nov 27, 2012 | 02:08 PM
AlexM425's Avatar
CL55 AMG
well what happened was when i bought the car the guy was fixing the lining and had it off the trunk and closed it on accident and after that it has not opened, i have tried the key and it dose nothing...you can just turn it but the lock dose not disengage = / i have had to techs look at it whit the snake cameras and they cant figure it out? have to take it to the dealer it looks like.
Old Nov 27, 2012 | 02:18 PM
awiner's Avatar
2003 CL55 AMG
It is very possible the cable is disengaged then. If that is the case, I have no idea how you will gain access without removing the rear seat and somehow getting between the framing.
Old Nov 27, 2012 | 04:50 PM
rbreaks's Avatar
Alex,
Mine was doing the same thing, where you could here it trying to open remotely but it wouldn't open. As awiner suggested, I used the manual key to open it. The trunk was still pressing down on me while I opened it manually, and then about half way up, it releases as normal and you can use the button on the trunk to auto close it -- but it still would not open remotely. I tried replacing the fuse in the back seat, didn't work and the dealer ended up fixing and replacing the actuator.
Old Nov 28, 2012 | 12:35 AM
AlexM425's Avatar
CL55 AMG
Ehhhh looks like time to take it to the dealer or try to find a used one online because me and my mechanic tried everything even a airbag, do you know if i could use one from a S500?
Originally Posted by rbreaks
Alex,
Old Nov 28, 2012 | 06:24 AM
rbreaks's Avatar
Maybe, but I really don't know, sorry.
