CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
147HP Gains for your CL63 AMG Biturbo! Velos Designerks @ Vivid Racing
Old Jun 14, 2012 | 08:45 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Velos Designwerks Performance Software
All Velos reflashes will receive a 15% discount for a limited time! MSRP is listed below.
**ECU must be shipped to Velos for reflashing**
First 3 customers to order get an additional discount!
CL63 AMG Biturbo(W216)
Through careful remapping of the factory ECU and countless hours of testing, Velos Designwerks is pleased to announce the release of its performance software for the M157 AMG 5.5 Liter Biturbo V8 Engine. Producing an astounding 535 hp and 560 lb-ft off of the assembly line, the Velos Designwerks engineering team has been able to increase this powerplant’s output to 670 hp and 720 lb-ft of torque (SAE Corrected).
The Velos Designwerks CL63 Performance Software involves a remapping of several of the factory’s ECU maps including, but not limited to, the fuel maps, throttle maps, ignition maps, and limiters. With this 25% increase in horsepower and over 28% increase in torque, the AMG 5.5 Liter Engine’s true potential is now unleashed.
While there are and will be other options available on the market, the Velos Designwerks Custom ECU Tune for the W216 AMG 5.5 Liter V8 Biturbo Engine produces real gains throughout the powerband that one can realistically expect to duplicate on their own.
Velos Designwerks offers a stage 1 and a stage 2 version of these tunes.
Performance Figures:
Stage 1:
Peak Horsepower Gain: 103 HP @4300 rpm (83 hp to the wheels)
Peak Torque Gain: 123 lb-ft @4300 rpm (98 lb-ft to the wheels)
MSRP: $1400 15% Discount until July 4th! Order now for $1190!!
Gains taken from a sample of runs done on the same dyno in 90+ degree conditions
Stage 2:
Peak Horsepower Gain: 147 HP @4300 rpm (120 hp to the wheels)
Peak Torque Gain: 186 lb-ft @4300 rpm (154 lb-ft to the wheels)
MSRP: $2600 15% Discount until July 4th! Order now for $2210!!
Old Jun 15, 2012 | 10:29 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Those are great gains!! Your butt dyno will definitely feel that.
R.K.
Old Jun 15, 2012 | 11:03 AM
Toadster's Avatar
2005 E55 AMG
kudos to a great tune!
may want to check your data between stage 1 and stage 2 though...
Stage1: Peak Horsepower Gain: 147 HP @4300 rpm (83 hp to the wheels)
Stage2: Peak Horsepower Gain: 147 HP @4300 rpm (120 hp to the wheels)
Old Jun 15, 2012 | 12:14 PM
Whoops! Looks like a copy/paste error has occurred lol
Thank You!
Old Jun 15, 2012 | 12:31 PM
radride's Avatar
Its hard to tell from the graphs you posted but does the A/F ratio get a little too lean (mid 12's)? That would worry me.
R.K.
Old Jun 15, 2012 | 12:51 PM
R.K.
Most tail pipe 02 Sensors read a bit lean being that far down stream, plus these newer motors are much more efficient and can go a bit leaner then you would think
Old Jun 28, 2012 | 08:46 PM
To the top!
Old Jun 29, 2012 | 12:33 AM
jacob502's Avatar
2008 C63 ,2009 SL 63 AMG, 2011 SLS AMG
Can someone explain to me what the diffrence is between stage1 and stage 2?
Is stage 2 also an ECU remmaping only or is there modifications to the exhust?
One other thing, the horsepower gains you are comparing are not peak horsepower. why are you recording the gains @ only around 4000RPM?
stage 1 gains: 474-391 ~83 Ok
Stage 2 gains: 489-369~ 120 OK
But the peak horsepower is as follows ( I assume this is a non PP car due to the low baseline of 474whp)
stage 1: 524-476~ 48HP
stage 2: 563-476~ 87HP
SO really the peak HP gain on a stage 1 is 48whp and on a stage 2 is 87WHP
Sorry, but you guys dont have the tunes that other tuners like Renntech or Weistec carry in terms of preformance.
Very smart advertising mid-range horsepower. Most people wont catch it. But people like me will
Seriously 147HP ?
How does 87 RWHP equate to 147HP at the crank? (you did post a claim of 670HP, which is a maximum peak horsepower and not midrange)
Old Jun 29, 2012 | 07:23 AM
SLS Qatar's Avatar
2011 SLS AMG, 2009 SL63 AMG, 2008 C63 AMG(SOLD)
Seriously 147HP ?
yeah I was wondering the same thing too
Old Jun 29, 2012 | 01:41 PM
All dyno's are going to read different numbers, that is why it is important to look at the gains made and not the peak power. I'll get with Velos about the specifics on the numbers.
Old Jun 29, 2012 | 02:07 PM
oliver@velosdesignwerks.com's Avatar
AMG
Seriously 147HP ?
Hey Jacob502,
The only difference between level 1 and 2 is software, both runs are from the same car with no other mods.
We advertise the peak gain and by gain we mean difference. The largest difference happens around ~4100 RPM. The difference at ~4100 RPM is 120 which would make 4100 RPM the area with the largest gain.
The dyno records the horsepower and torque at the highest point for that particular run, it does not compare the point that has the largest difference. That area is highlighted by the line in each run.
The 147 BHP is found from adding the estimated drivetrain loss to the largest difference of 120 RWHP at ~4100 RPM.
Old Jun 30, 2012 | 01:06 PM
jacob502's Avatar
Originally Posted by VelosDesignwerks
Hey Jacob502,
I understand. You are clarifying what I had already posted above.
But then that makes your 670HP peak at the crank incorret, since it is peak horsepower and not peak gain. You gained 87HP at the wheel at peak, which is nowhere near 670HP peak at the crank!
Old Jun 30, 2012 | 01:50 PM
AMG
Hey Jacob502,
A tuned car will achieve a maximum of ~670 BHP which is the peak power made by our stage 2 (peak number recorded by the dyno run). Seen on 'runfile_004' in the original post.
While making a peak figure of ~670 BHP there is a maximum gain of 120 BHP over stock @ 4100 RPM.
We provided the peak power and the peak gain/difference.
In other words our stage 2 will provide a peak of 670 BHP with a maximum gain of 120 BHP @ 4100 RPM over stock.
Feel free to let us know if you have any other questions.
Old Jul 6, 2012 | 12:58 PM
Extending the sale beyond the 4th of July BUMP! WOOOOOOO!
Old Jul 9, 2012 | 08:43 PM
Tons of interest and they're still on sale!
Old Jul 13, 2012 | 08:12 PM
Old Jul 31, 2012 | 05:50 PM
