CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Lower front "control arm ..." :S
Old Jul 16, 2012 | 02:37 PM
bimerbenzbently's Avatar
CL55 AMG/S55 AMG
Im told that there are 2 FRONT lower control arms but i could one find one of them.
Does anyone know the name of the second control arm or have a link to a website.
Old Jul 16, 2012 | 02:47 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Number 11 is the front lower control arm and 7 is the rear lower control arm.
Old Jul 17, 2012 | 09:27 AM
CL55 AMG/S55 AMG
Thanks alot!
So i got number #11 but still gotta get number #7 (rear lower control arm)
Can you recommend a place to buy that besides the dealership please, i had no luck finding it anywhere.
Old Jul 17, 2012 | 12:40 PM
OCKlasse's Avatar
MBworld Guru
http://www.oediscountparts.com/parts...iagram=5781370
$255 a piece, which seems pretty fair...is there a reason you need to replace the entire arm?
Old Jul 17, 2012 | 01:48 PM
CL55 AMG/S55 AMG
i heard some squeaking when going over bumps and leaving my driveway, so i got it checked out, turns out my control arm needed replacement on the drivers side so i replaced both.
still have a minor squeak when turning the steering wheel at certain times, so i got it checked out again, it was funny when they said control arms since i just changed them.
I didn't know the front had 2 lower control arms, either way thanks alot for the link because they wanted 500$ each and you just saved me $$$ that can go somewhere else on the car
Old Jul 17, 2012 | 02:02 PM
OCKlasse's Avatar
MBworld Guru
Sounds like you just need to replace the ball joints, and not the entire arms.
Old Jul 17, 2012 | 02:09 PM
CL55 AMG/S55 AMG
yeah but apparently i have no choice since its too much work to just get to the ball joints, i rather just get the new arms with ball joints and pay 2 hours labour and call it a day
Old Jul 17, 2012 | 02:54 PM
awiner's Avatar
2003 CL55 AMG
Ball joints are simple and quick to replace using the correct tools.
The lower control arm bushings are tougher to replace and need the right cup and press.
Old Jul 17, 2012 | 04:12 PM
OCKlasse's Avatar
MBworld Guru
My buddy and I replaced my ball joints with the correct tools and it was fairly straight forward. A little scary at times (dismounting all joints), but certainly easy enough.
Old Jul 18, 2012 | 10:11 PM
alx's Avatar
alx
One lower control arm (the rear one on the front). The one the front is called "radius arm". All bushings are serviceable but do require a press out tools. The press in is easy with a shop press.
Be careful with the rubber bushings. They are all hydraulic and if forced the wrong way will spray oil. Ask me how I know.
Squeaking without free play can be silenced with lubricants. Free play is cured by replacing.
Parts.com is the cheapest oem parts source.
It is a fun weekend project of you have the tools.
Old Jul 19, 2012 | 11:25 AM
red60R's Avatar
2017 C63S
you're always posting really good stuff man...seriously, when I see your posts you are always trying to genuinely help out other members. It doesn't go unnoticed :-)
Old Jul 19, 2012 | 02:12 PM
CL55 AMG/S55 AMG
i ended up buying 2 front rear control arm and new ball joints from oediscountparts.com
thanks for all the help
Old Jul 19, 2012 | 03:14 PM
OCKlasse's Avatar
MBworld Guru
Thanks! I always try to help when I can.
That's why we're all part of a community (end the sappy cliché).
Old Sep 10, 2014 | 08:22 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
Maybe someone can help me out. Does the lower control arm (#7) attach to the strut with hardware of any type? My control arm doesn't want to separate from the strut, and I suspect the female torx head I see at the bottom of the strut might be some type of retainer. Thanks.
Old Sep 10, 2014 | 08:45 PM
Grip Grip's Avatar
Got it. Big thanks to Jason at BIP.
Old Nov 22, 2015 | 09:45 PM
khutchinson22's Avatar
CL55
Can the ball joints of both the frontmost and rearmost lower control arms be replaced? It seems like just the rearmost can but I wanted to double check before buying the entire front lower control arm.
Also, are all 4 (left and right, front and rear) ball joints the same part number?
Old Nov 29, 2015 | 12:02 PM
CL55
I figured out the answer to my question above and now have all the parts. Now, what all does the job entail? Sounds like its pretty straight forward but i have very little suspension experience and i dont know what all to remove or watch for.
