*Video* Resonator delete done, BEST MOD YET! All Info and install inside--
It sounds like an Aston Martin mixed with a Ford GT.
And cruises just like the stock setup. Perfect.
I like the not too bothersome sound. At idle and light cruising, it's like stock. Which is just how I had hoped it would turn out. Hit the gas, and you can hear it means business. Sweet.
Also, I'll need to get some full throttle vids, this one was done late in the evening so I didn't want to be racing around the residential neighborhood, and didn't feel like going out to try to find a deserted place.. I only was pressing about half throttle in the acceleration clips. But I will eventually get some better vids up..
But besides that, I agree that resonator delete was one of my favorite mods
1) delete mufflers only
2) delete both resonator only
3) delete both muffler and resonator
Would be interested to hear from the perspective of a V12TT owner if possible
http://www.ebay.com/itm/UNIVERSAL-AL...NYdJdY&vxp=mtr
Also I see the OP has a CL55, I have a '08 CL63, are the two exhaust systems identical enough that the procedure is just as straightforward on both respective cars and the techniques being the same (resonators in the same areas, etc)? Also I see some people recommending removing both resonators and others doing just one side with a straight pipe. Could someone expand on the difference in the two different techniques in terms of sound and whether in California there could be a difference in passing an emissions test. My car needs a smog cert every two years.
Please provide crisp answers so when I go to Midas or wherever, I gan give them exact instructions leaving nothing to chance because I know nothing about the topic. I will be parroting exactly what you guys tell me.
Thanks in advance.
Thanks in advance.
I would suggest that you go to a custom exhaust shop shop and talk to them about what you want. Get the car up on a lift and look at the exhaust. The reason people use x-pipes is usually because they remove the 3rd cat which essentially functions as a merger point for the exhaust gasses on a stock system. At leas that's how the CL55 is setup.
OK what about the one res, two res options?
What part of Ca are you in?
