CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How To: (Video) Replace / upgrade your Intercooler pump, with Bosch part numbers.
Old Jan 6, 2013 | 09:43 PM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
Exclamation How To: (Video) Replace / upgrade your Intercooler pump, with Bosch part numbers.
In this video, I'll cover the simple procedure of changing your intercooler pump.
This is a common problem:
Driving fine, and after some hard pulls up to redline, the engine loses power.
9 times out of 10, your intercooler pump is the culprit.
Try turning off the engine, waiting 15 seconds, and turning it back on.
If this "solves" the problem for a few minutes, then you need to follow this simple guide.
Tools required:
*Coolant, MB 325.0 spec: BQ 1 03 004
*Bosch Intercooler PUMP: 0392 022 010
*10mm socket
*Jack and stand
* 2x $10 Hose clamp tools (shown in video)
*Flat head screwdriver
WATCH THIS VIDEO
-Jack up the car and set it on a stand
-Unplug pump electrical connection plug on the rear of the pump.
-Undo the pump fastener, the single 10mm head bolt. The pump will now hang down, with only the hoses attaching it to the car.
>The goal is to clamp the hoses as close to the pump as possible. You'll lose virtually no coolant. <
-Then simply remove the hose clamps with a flat head, and pull of the lines.
-Install pump in reverse order.
(If you did not clamp hoses, or if you opened the drain valve on the radiator to flush and refil with new coolant, fill the expansion tank full, and run car with cap off and heater on high for 10 mins. Keep refilling coolant, and then let things cool down and check the level.)
Bleed process:
Hope this helps!
Old Mar 31, 2013 | 11:47 AM
slonar21's Avatar
CL600 2003
Do you need to change the electrical connector on the bosch or is it 100% plug and play?
Old Mar 31, 2013 | 12:11 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
The Bosch unit is plug and play. No modifications needed.
R.K.
Old Mar 31, 2013 | 04:47 PM
John 99CLK430's Avatar
1999 CLK430 (sold) 03 CL55
It's almost scary to know the pump wasn't working at some point, temps were reaching coolant temps! The old pump that stopped working was a Bosch 0 392 220 003 unit. 010 was installed and working good thus far.
Old Mar 31, 2013 | 09:50 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Damn, rocking a 55 now too, John?
Old Apr 1, 2013 | 12:03 AM
Yessir, I just picked it up last week. Amazing car with little complications here and there that need addressing. Feels good to be back
Old Apr 3, 2013 | 04:35 PM
slonar21's Avatar
CL600 2003
Just ordered one off ebay, the pump is so inexpensive not even worth checking if my old one still works.
Old Apr 28, 2013 | 08:50 AM
capn_shawn's Avatar
2005-CL55, 2006-R350
Did this last night.
Farly simple, but there was no way for the "clamps" in the video to work (not nearly enough room) but I managed with two needle-nose vice grips covered in 1/4" fuel hose.
Question is: My old 003 pump had an air line / vacuum line attached and the new 010 pump had a place to put it but it was just a stud. Anybody know what that air line was for? Looks like there is no air line on the old pump in Nidaynazo's video. PS: Mine is '05
Old Apr 29, 2013 | 08:06 AM
cm60k's Avatar
nidyanazo,, You always done & do a great job,,
do you know the difference in flow/PSI between the old one & the updated one......??
ZAYED,,
Old May 9, 2013 | 11:30 PM
gazosnic's Avatar
e46 m3, w211 e55
what is the procedure to bleed the new replacement bosch pump? The second video doesnt look like its working.
Old May 10, 2013 | 10:00 AM
radride's Avatar
There is no need to do so. In the other video he showed the flows and its pretty clear that the system burps itself. Now that only applies to the 55K motors and not the TT 12 motors.
R.K.
Old May 13, 2013 | 10:38 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
The Bosch is a nice quick flix but if you want a much better flowing pump and more durable,, then go with the Mezzire WP 136. Does take a cutom bracket to make fit but not to hard of a job and worth the flow. IMO
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 17, 2013 | 12:32 PM
merc79's Avatar
s55 AMG
How come he got banned? He was sharing some very nice info for all....damm
Old Jun 4, 2014 | 11:28 PM
Mackhack's Avatar
Did you replace yours with the Mezzire WP 136? I was looking for the EWP-80 or Johnson CM90 for much better throughput and therefore more cold air to replace my stock one.
The formula is for every 10 Degree Celsius lower air intake temperature, 1% more power.
Old Dec 9, 2014 | 09:19 PM
Afr00t's Avatar
'03 CL55 AMG & '09 SL63 AMG
Can someone clarify the symptoms of a bad IC pump?
Old Dec 9, 2014 | 09:26 PM
Mackhack's Avatar
You push the pedal and you think you're sitting on a tracktor. No more supercharger power. That's the symptom. Reason: water temp of the low temperature circuit is 100 degrees Celsius hot (for Americans, it's boiling temp). As soon as it's goes down again you have your mo pressure power back.
Old Dec 9, 2014 | 09:43 PM
Afr00t's Avatar
Does the car jerk too? As if it's choked up?
Old Dec 9, 2014 | 09:59 PM
Mackhack's Avatar
If it does that and the gas gauge is within your reserve then the feeder bowl might be leaking or one of the fuel pumps sucking from the feeder bowl is not working right.
Old Dec 10, 2014 | 08:19 AM
Afr00t's Avatar
It does it regardless of how much fuel is in it. It jerks when i gun it or when the car is on low rpms. And it's also hesitates and jerks more when the car is still cold.
Old Mar 27, 2019 | 08:33 AM
MrTracy's Avatar
2007 S550 & 2009 CL63 AMG & 2009 BMW 328i Convertible
V12tt
Is this the same pump that will work on the V12TT?
Old Mar 27, 2019 | 09:30 AM
Puerto Rick's Avatar
2003 CL55 AMG Komp.
Good info. Easy way to check for a bad pump is that after the car gets to operating temp, the intercooler will not be warm to the touch.
