Rebuilt Rear ABC Valve Block Today
Does anyone know anyone in the Bay Area who will take them
Out , rebuild them and reinstall ?
Here are the O-ring sizes. type: Nitrile (Buna-N)
inches_____actual_____ID____OD_____width
0.07______0.739______7/8____1_______1/16
0.07______0.614______5/8____3/4_____1/16
0.07______0.551______9/16___11/16___1/16
0.07______0.489______1/2____5/8_____1/16
0.07______0.426______7/16___9/16____1/16
Is your car still holding up on static height?
i'm having some problems with my rear suspension, so I want to replace the o rings.
But i don't know exacelly how i need and what i need to order, and how much of them, because i'm going to take it apart after i have the rings here.
I'm from the netherland en would like to ask you if you can give me the exact link with the right O rings so that i can order them.
the front suspension is already done, i had replaced the whole block, that's good now.
greets Danny
I had to replace my rear valve several years ago and for the life of me, I couldn't see how you could open these valves without destroying them?
The new valve I installed (different manufacturer) appears to be made to open up-
Thanks!
Elm
http://www.ebay.com/itm/141512421148?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
For those who don't want to please PM for details and I can help do this work for you.
BUNA 90 O-rings from APG
H90018 .739" ID x .070" C
H90015 .551" ID x .070" C or V90015
H90014 .489" ID x .070" C
H70013 .426" ID x .070" C
H90016 .614" ID x .070" C
This list currently does not include the large o-ring that seals to solenoid to the block as it's doesn't wear.
Some solenoids use what look like PTFE white spacers along with the O-rings while other blocks have spacers made of square cut rubber rings. If yours have these rubber spacers, which sometimes are damaged presumably on original assembly, the parts numbers for these are as follows;
APG #SH70013 , #SH70014 , #SH70015 , #SH70016
The square cut rings can be tricky to install without splitting them. You can hear them split on reassembly.
Quantities are a couple per solenoid.
00 06 Mercedes W215 CL500 CL55 AMG CL600 SL55 AMG SL600 Suspension Valve Block | eBay
Thank you
so today i pulled the rear valve block and rebuilt it , to my surprise it was very easy to do and thought i would share some pictures of what i did .
i used the green o-rings that are CHF compatible .
it is very easy to remove and you will only lose about 3/4 liter of fluid .
jack the car and take the weight off the rear suspension , there are nice spots to put jack stands just behind the rear wheels .
here is the unit out of the car and ready to disassemble i removed the bracket and relief ball on the bench .
when removing the clips i placed a small screwdriver under each side while very carefully squeezing them with pliers .
once the clips are removed they are very easy to turn 45degrees , i then put a wrench under them to help with leverage and pulled them out
another handy pair of pliers to use
as you can see the o-rings are shot
block all clean
new o-rings installed
the other ones
all done and ready to go back in car
the solenoids are very easy to push back in and turn to where the need to be , everything is color coded but i did mark the blocks per color just in case i washed the paint off .
overall a very easy job and took about 2hrs to complete .
once i had it back in the car i lowered it down with the jack still holding the rear up to where it would sit normally and started the car for about 30 seconds and pushed the abc raise button on the dash and then lowered it , shut the car off and topped of the fluid about a half a liter .
started it again and cycled through the raise and lower about 10 times then topped off fluid , it now has been sitting for over 2 hrs and has not dropped at all , the o rings were very hard and were coming apart .
front valve will be next .
Dave
I'm very keen on replacing these & found the seals but having great difficulty replacing them
