CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
(COOLANT! VISIT WORKSHOP!) Any help?
Old Feb 3, 2013 | 11:54 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
About a week ago I went to visit my future parents in law that live about 30min drive away from me. When I was coming back home that night my fan went on and stayed on for a very long time (it was 20F outside) The car was not overheating so I kept driving. The fan was now on for about 5 straight minutes and I decided to pull over. I pulled over shut the car off and the fan went off. When I restarted the car the Fan came back on and about 5 minutes into the drive it shut off and stayed off for the entire 15 minutes of the drive that was left to get home. Since last week I have not started the car or drove it because of snow on the roads here in Chicago. Today I decided to start it up and let it run a bit after about 5 min of idle a msg showed up (COOLANT! VISIT WORKSHOP!) and the fan kicked back on even tho the car was not on for the entire week and didn't even get a chance to warm up. I shut the car off and went on my way to a birthday party in our other car.
In the next week or two I'm taking the car in to do a IC PUMP, Rear Tank, Heat Exchanger and also Downpipes to SPEEDRIVEN. Before I ask Speedriven to look into the problem can anyone here help me on what this could be? I have searched and read a few threads that it could be a bad wire but who knows. I rather fix the problem myself if I can.
Any ideas or maybe someone had this issue before? I will check tomorrow to see if I'm loosing any coolant but I'm 90% sure I'm not since you can smell it right away once you start loosing it.
KAMIL
Old Feb 4, 2013 | 12:17 AM
awiner's Avatar
2003 CL55 AMG
How is your coolant level ?
Old Feb 4, 2013 | 09:42 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
do a pressure test on the cooling system.
the radiators are know to go bad or weep coolant from time to time
Old Feb 4, 2013 | 09:46 AM
alx's Avatar
alx
check coolant level.
have the car read.
the message on the dash would have thrown a few codes in das.
Old Feb 4, 2013 | 02:58 PM
I will check my coolant level today when I get home, I guess that is the first thing I should have done. I will also do a pressure test tomorrow since I have to get the pressure guage to do it.
KAMIL
Old Feb 4, 2013 | 05:57 PM
Ok, no coolant in the tank. Before this happened I remember driving down the highway and hitting something under the car.Something on the road it was a pretty loud bang and I looked outside and leaned down to look under car but everything was fine. Going to Mercedes to pick up some coolant to see if it leaks under car when I fill it.
Old Feb 4, 2013 | 10:42 PM
alx's Avatar
alx
Check also engine oil for milky color. I hope not, but it doesn't hurt to lookie lookie just to be sure.
And you don't have to buy coolant from dealer. Your local napa/ pep boys/ etc. store has zerex g-05 for mercedes Benz. Cheaper and identical to the dealer coolant.
Old Feb 5, 2013 | 09:42 AM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
