Dyno!
Here's my dyno:
This year I plan on getting a tune and next year my plan is turbos and intercoolers.
3000 stall converter for street or strip
11" diameter vs stock 12"
10 lbs lighter than stock to reduce rotating mass
triple lock up clutch
high performance pump and bearings
all new and no core charges!
Whole new unit not made from cutting up a stock convertor
I have a 3K stall from Pro torque and its definitely acting funny. Shifting is not done properly and it appears I can not use Manual mode as it confuses the tranny.
Sorry to thread jack, carry on.
Here's my dyno:
Check out this link this is another guy with a high powered M275 with a stall. It may be hard to compare since he is very far from stock suspension along with roll cage and additional bracing.
https://mbworld.org/forums/m275-v12-...66-120mph.html
Was there a need to flash the TCU? If not removing the torque limiter would really show what the car can do, even more so with an ECU flash. Good luck with the new setup.
