CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL65 turned off while driving... anyone else have this happen??
Old Apr 24, 2013 | 12:30 PM
BiTurboBrunette's Avatar
CL65
I have an '05 CL65 with 47k miles. I was driving on the freeway last night and it turned itself off while at freeway speed. I lost power steering, which I'll tell you is nice to have, especially when driving faster. :P It's a good thing I wasn't going through a corner, or I likely would've had a bad accident. I got the car to the side, put it in park and it restarted just fine. No warnings, nothing.
I had to replace one of my ignition coils a few months ago and know that my other one isn't far behind. Could this be a coil issue? Now I don't feel like I can trust my car. If it were to happen again while going around a tight corner, I'd be screwed. And even worse, it would be awful if that happened when other drivers were close that I could potentially hit. Not cool.
Thanks for any advice....
Old Apr 24, 2013 | 02:22 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
check the ground connections on the coil pack harness they get loose from time to time.
Old Apr 24, 2013 | 07:44 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Any chance you bumped the key or hit a large bump right before it shut off?
Old Apr 24, 2013 | 08:04 PM
CL65
BlownV8, not that I'm aware of. I had been driving for quite awhile on the freeway...
Brought it in to a friend's shop & they plugged it in. No codes. Bringing it to a Benz/AMG specialist who thinks it may be a crank sensor...
Old Apr 24, 2013 | 09:22 PM
BlownV8's Avatar
Do you have a lot of stuff on your key ring?
Old Apr 24, 2013 | 09:45 PM
alx's Avatar
alx
The "no codes" shut off is a dead give away. It is your cps. They begin to fail when engine is hot and will start working again when engine cools of a bit. It gets worse in time.
Cheap and easy to replace.
Coils will not just quit- there will be misfiring and codes.
Old Apr 24, 2013 | 09:52 PM
CL65
BlownV8, I just carry the single key. No key ring, other keys, etc.
alx, got it ordered
Thanks everyone for your advice
Old Apr 24, 2013 | 10:22 PM
NISMO240SSX's Avatar
CL63 N/A 2008
second the cps. same thing happened to me, turned off came right on. as it gets worse you have to give the car a few minutes to cool before it turns on.
Old Apr 24, 2013 | 11:35 PM
BlownV8's Avatar
Typically when a cps is bad enough to shut the car off it won't restart immediately. No codes lean toward a bad cps or that your key lost contact with the ignition for a moment.
Old Apr 25, 2013 | 02:23 AM
Welwynnick's Avatar
2006 S600
Forgive my ignorance, but what's a CPS - coil power supply?
Thanks, Nick
Old Apr 25, 2013 | 02:47 AM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
Crank position sensor
Old Apr 25, 2013 | 12:05 PM
shardul's Avatar
A faulty CPS should trigger a CEL
Old Apr 25, 2013 | 01:15 PM
alx's Avatar
alx
i've seen several cars with bad cps and all had no (related) codes maybe i have gotten "lucky"...
Old Apr 25, 2013 | 01:17 PM
layzie12g's Avatar
2008 Mercedes Benz E63
I also have seen 5+ cars with bad CPS and no CEL.
On my car I had a loose plug on the ECU which caused the same thing to happen. It was hard to track down because it was one of those things I thought was just about impossible to happen.
Old Apr 25, 2013 | 04:52 PM
alx's Avatar
alx
oh, they throw codes alright.
ugly unrelated ones - "low fuel pressure", "cam sensor failure", "throttle position implausible" and the like.... god help you if you start reading too much into them...
Old Apr 25, 2013 | 09:50 PM
BlownV8's Avatar
I've experienced the same - no CEL.
Old May 10, 2013 | 06:02 PM
CharlestonN's Avatar
03' CL55 AMG
I had this happen to me and it was the CPS but i also recently had my car shut off while driving and restart instantly and never had the issue again
No errors or anything it was very strange and to this day i have no idea what it was
Old May 10, 2013 | 07:24 PM
BlownV8's Avatar
Had it happen too. It was caused by my knee accidentally bumping the key. The second it looses contact the car will turn off.
Old May 10, 2013 | 07:41 PM
03' CL55 AMG
Yeah, that might have been it, i am 6'2 with long legs so i might have kneed it and not noticed
It kind if freaked me out when it happened though because i was coming to a stop at a stoplight and the brakes got stiff when the car went off
Old May 15, 2013 | 04:53 PM
RNSL65's Avatar
SL65 AMG, X5-4.8i M-Sport, 530D, 528i
My Sl65-AMG had a bad Ignition Coil Power Supply, no CEL or codes stored!!
Old May 15, 2013 | 05:22 PM
alx's Avatar
alx
that usually manifests itself by engine not running at all...
Old Oct 12, 2013 | 04:03 PM
RNSL65's Avatar
I my case it engine did go normally when cold but when in normal warm condition it failed like it was one of the ignition coil banks. But it showed up to be the ignition power supply.
Old Jan 29, 2014 | 03:49 PM
Aladdin23's Avatar
2014 CL65 AMG
I am having same problem on my 06 S65…if it is indeed the CPS, then how much would it cost to fix/replace what needs to be fixed/replaced?
Old Jan 29, 2014 | 06:03 PM
03' CL55 AMG
For my CL55 the part was around $95 (OEM on PartsGeek.com) and the labor was about the same but from what I've heard it's an easy DIY job
I just checked for the 06' S65 and the oem part is only $41 for your car on partsgeek
Old Jan 29, 2014 | 07:23 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
Most likely coil pack, My SL65 did the same thing when I came close to a stop, then after awhile car ran really rough turned it off and on and it was fine. Scanned it the next day and found out it had 10 misfires lol. After replacing the ignition coils, no more random turn off issue
