CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
W216 cl63 AMG break calipers down-grade vs W215 55?!?!?
Old Jul 17, 2013 | 10:42 PM
anton28's Avatar
2023 Rover
I just inspected the brakes on my cl63 and to my surprise and shock the front calipers are nothing more then two separate one piston calipers bolted to one braket and fited with AMG covers that make it appear to be a 6 or 8iston caliper. WTF?... The rear is a much smaller one piston caliper, again with a AMG cover on the outside to make it appear like its a 2 or maybe a 4 piston caliper. What is this all about? Why did they not install the same 6 piston fronts and 4 piston rear calipers on these cars like the old cl55 cars had? I'm very confused about this right now.
Old Jul 22, 2013 | 01:44 PM
anton28's Avatar
2023 Rover
No one here has questioned this?
Old Jul 22, 2013 | 02:09 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
That's the first I'm hearing about this...
R.K.
Old Jul 22, 2013 | 02:11 PM
biker349's Avatar
cl600
a bit off topic, but i was quoted 2, 21/2 hours to replace the rear pads and rotors on 2004 cl600. seems a bit high. what do you guys think?
thanks
Old Jul 22, 2013 | 02:12 PM
radride's Avatar
thanks
I would say 1 hr max.
R.K.
Old Jul 22, 2013 | 03:48 PM
NISMO240SSX's Avatar
CL63 N/A 2008
I noticed the same thing when I did my rear pads, and the pads are the same as a ML, but the braking works on my 63 similar to the my 55 so I'm not too worried.
Old Jul 23, 2013 | 05:05 AM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
It's not the number of pistons, it's the area they cover that matters.
Old Jul 23, 2013 | 10:26 AM
alx's Avatar
alx
the 60-0 distances for both car are pretty much identical (112-115 feet) and is limited by front tire contact patch vs. weight over tires (static + dynamic weight). stopping power is not the limiting factor.
on the other hand multi-piston calipers are more complex and more prone to sticking so the newer calipers are addressing this a bit. divide and conquer strategy is used in this case.
rear calipers are pretty much irrelevant as in emergency brake situations the rears are used strictly to keep the rear tucked going in the direction of the turn of the steering wheel (via abs + stability control). rear braking force is really not used for stopping purposes. in that sense simple dual piston (or even single piston- sliding type) calipers are sufficient.
Old Jul 23, 2013 | 01:01 PM
anton28's Avatar
2023 Rover
Seems very cheap in my opinion. You don't see this type of brake set up on any other performance sedan. Every other line of AMG cars is using the big monoblock calipers. C, E CLS, SL etc. The car does top very well but I wouldn't consider this set up being a performance break set up by any stretch.
As far as
"on the other hand multi-piston calipers are more complex and more prone to sticking so the newer calipers are addressing this a bit. divide and conquer strategy is used in this case"
Ive had zero issues with any of my cars with 6-8 piston calipers. If anything this w216 set up is so much more to maintain then the w215 brake set up as far as replacement pads and rotors.
Old Jul 23, 2013 | 02:59 PM
bhamg's Avatar
C63 AMG
[QUOTE=anton28;5716878]I just inspected the brakes on my cl63 and to my surprise and shock the front calipers are nothing more then two separate one piston calipers bolted to one braket and fited with AMG covers that make it appear to be a 6 or 8iston caliper. WTF?[QUOTE]
I have one word for this...LAME.
Old Jul 23, 2013 | 03:23 PM
alx's Avatar
alx
As far as
nascar has some of the nastiest braking requirements and yet their front calipers are four piston simple big calipers. number of pistons increases complexity and reduces reliability.
they work. what else you want from brakes?
Old Jul 23, 2013 | 05:45 PM
anton28's Avatar
2023 Rover
[QUOTE=bhamg;5723296][QUOTE=anton28;5716878]I just inspected the brakes on my cl63 and to my surprise and shock the front calipers are nothing more then two separate one piston calipers bolted to one braket and fited with AMG covers that make it appear to be a 6 or 8iston caliper. WTF?
Exactly!!!
Old Jul 23, 2013 | 05:47 PM
anton28's Avatar
2023 Rover
I understand that they work. What i don't understand of why AMG went out of their way to fit these cars with this set up VS every other model with the big monoblock calipers.
Even if they do work. Im sure everyone here would pick the 6/4 piston set up vs this crappy ****.
Old Jul 26, 2013 | 03:11 PM
Quadcammer's Avatar
96 and 08 911 turbos
why is it crappy **** if it works and the car brakes well?
If MB made brake pads and calipers made of banana peels yet they stopped the car as well as the 6 piston calipers, I would be fine with banana brakes.
Old Nov 19, 2013 | 12:19 PM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
interesting discussion.
In this day and age, ppl are piston hungry….they believe more piston = better the stopping power…at least that's what we are lead to believe, right? LOL!!
I've taken apart calipers and rebuilt them….and the multiple piston calipers obviously have more moving parts. They also have much much smaller pistons.
The double single-piston design now employed on the CL63 are probably much bigger pistons compared to the CL55 6-pot caliper w/ smaller pistons. The stopping power is probably the same…just my 2 cents.
