I could not let this one die...
Almost exactly a year ago, I saw the 2003 CL55 below at auction. It was one of the victims of Super Storm Sandy in the NorthEast of the US (Long Island) and I could not pass her up. Car went for unbelievably cheap and I had to pull the trigger. I purchased the car based of a few low resolution auction pictures, but based on the pictures I did see, car appeared fairly clean. It was being sold with no key, flood damage, electrical damage... I still had to pull the trigger.
Fast forward to a few weeks ago, I finally got the car running with the help of this forum, a few other forums, Google, and putting in some hours troubleshooting electrical issues.
If you take a look at the door, you can clearly see the water mark of where the flooding reached. Water also entered the fog lights.
Luckily, the water intrusion to the cabin only affected the passenger side. The rear SAM/fusebox were destroyed, the phone module was destroyed, alarm & window module were iffy, no obvious signs of water damage, but it was too early to tell. In the pic below, you can see the soot, silt, dirt, minerals that settled under the passenger side carpet.
Compared to the passenger side, the drivers side is surgically clean.
I had to replace this pre-fuse block, the previous owner tried to start the car while the rear fuse block and SAM were swimming in salt water.
I was not getting power to the EIS so the key would not turn, I had to put a jumper wire on the EIS fuse to allow the key to even turn, but even after I added the jumper wire, the car would not start or crank. Just ACC & IGN...
Here is where I spliced in all new terminals/connectors/pins to all modules under the rear passenger seat.
After all the salt water was dried out/evaporated, this is what your carpet looks like...
From bottom to top... 2006 phone module, 2003 water damaged phone module, 2003 water damaged rear SAM/fuse block.
This shot shows the first time the car has moved under its own power in almost a year. After the car started, amazingly the suspension rose right up and no ABC issues with the exception of the right front suspension height being ever so slightly lower than the left side... 1/4" or so lower. Shortly after this shot, I gave her a well deserved bath with the pressure washer to get off almost a year of dirt. Car looks pretty good for not being washed in almost a year.
1. Belts, pulleys, & bearings were noisy. Replaced a few items on the front of the motor including supercharger bearing (thanks to this forum)...
2. Rear rotors were in bad shape, replaced pads, rotors, and emergency brake shoes, also cleaned calipers.
3. Parking brake lever wouldn't stay engaged and the release lever felt sloppy and wouldnt spring back, fixed that.
4. Still need to perform some ABC preventative maintenence & replace rear wheel bearings, then I can have some fun...
If you are having parking brake issues such as the foot lever not staying engaged, the release handle not pulling itself back in, no spring tension, excess slack in release lever, or the feeling that your parking brake is partially engaged, this may be your problem:
1. First you have to remove black plastic cover that hides the mechanism
2. Pic of the cover removed
3. My issue was the black L shaped rod directly above the spring had jumped out of the pocket that it is supposed to sit in, once I put it back in place, all was good. I also bent it inward some more so hopefully it does not happen again...
Thanks.
Thanks.
Thanks.
She already has... large grin every time I step on it...
Will do.
Thanks.
Thanks.
