CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Speedriven V12 SS Downpipes/DIY Flanges
Old Jan 6, 2014 | 12:50 PM
Speedriven1's Avatar
Speedriven
Speedriven Stainless Steel Downpipes
Our plug and play downpipes are now one sale. Come with direct bolt factory flanges. They are complete stainless steel. Both catless and cated pipes will not throw a cel light.
-stainless steel
-direct fit
-factory style flanges
-no cel
-20hp and 30trq
Fitment
03-06 CL65/600
03-06 SL65/600
03-06 S65/600
Prices
SL $1190 Catless/$1390 200 cell cats
CL $1090 Catless/$1290 200 cell cats
S $1090 Catless/$1290 200 cell cats
Speedriven V12 Turbo flanges
These flanges are for DIY guys. They are designed to match factory flanges and clamp.
-stainless steel
-direct fit to factory
Fitment
SL/S/CL 03-current
Price
$100 shipped in US-Pair
Speedriven V12 Exhaust Flanges
For DIY guys. These flanges are needed when bolting a custom downpipe to oem exhaust.
-direct fit to oem
-stainless steel
Fitment
S/CL 03-06
Price
Old Jan 6, 2014 | 12:56 PM
alx's Avatar
alx
those look awesome methinks and they look like they will make power...
pricing is not bad at all either...
Old Jan 6, 2014 | 01:04 PM
Speedriven
That they do.
Old Jan 6, 2014 | 02:24 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice machining!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 6, 2014 | 02:39 PM
Speedriven
Originally Posted by Exotic-metal55
Nice machining!
Thank you! Its all in house
Old Jan 6, 2014 | 02:46 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Awesome downpipes !!!
Old Jan 6, 2014 | 03:11 PM
xabo's Avatar
'20 S63
Nothing for the W216?
Old Jan 6, 2014 | 03:17 PM
Speedriven
Will have them coming soon!
Old Jan 6, 2014 | 03:34 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
very good pricing!
Old Jan 6, 2014 | 04:05 PM
Dr Matt's Avatar
05 CL65
Are these going to be an item you keep in stock or just limited production and only available for a while? Would like a set but have a few other things I need to spend money on before more performance mods.
Old Jan 6, 2014 | 04:23 PM
Speedriven
We don't keep downpipes in stock but are ready to be made at anytime, its about 1-2 week production time after payment. This is the new set price for downpipes.
Old Jan 6, 2014 | 04:32 PM
Dr Matt's Avatar
05 CL65
Awesome, thanks.
Old Jan 6, 2014 | 04:51 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Sure. Come out with them after I sold my CL. Great price for sure.
R.K.
Old Jan 6, 2014 | 04:58 PM
Speedriven
R.K.
We have had these for awhile, but never really advertised them till now. Plus they were double the price back then.
Old Jan 15, 2014 | 05:07 PM
RaceHorse's Avatar
CL65
Is anyone else jumping on a set of these or am I going to be enjoying them by myself???
Old Jan 15, 2014 | 05:34 PM
Speedriven
A few are being built as we speak
Old Jan 15, 2014 | 09:43 PM
eaks's Avatar
2005 CL65
So this is for the downpipe and midpipe? What exhaust setups do u have to pair with this? Sound clips?
Old Jan 16, 2014 | 10:21 AM
Speedriven
These are just downpipes, there is no need for aftermarket exhaust for these cars. They are about 2.8 inch's and is more then enough.
Old Jan 16, 2014 | 10:54 AM
eaks's Avatar
2005 CL65
Can you PM me a price on a setup complete for a 05 CL65 (including the adapters for stock exhaust clamps) shipped to Calgary, Alberta Canada (T3M0R5)?
Old Jan 16, 2014 | 11:13 AM
Speedriven
Pm sent
Thank you
Old Jan 17, 2014 | 08:46 AM
Bromaguire's Avatar
CL600, SL600, Quattroporte, S/C Denali, Turbo M3, H1
How much louder would my CL600 be if I retained the stock exhaust and put in your cat less downpipes? Also how much whp would I see without the tune being adjusted?
Old Jan 17, 2014 | 10:17 AM
Speedriven
It will only get louder under heavy accel. We have seen 18-24whp on a s600 with tune only
Old Jan 18, 2014 | 12:15 PM
RaceHorse's Avatar
CL65
At what point do you feel its necessary to increase the exhaust size? Is it safe to assume with your down pipes and upgraded stock turbos the remaining stock exhaust will still be sufficient? I'm just thinking of possible future mods. Either way the point of connection still remains the same size on the stock turbo housing, its just a matter of if increasing the entire way back is even worthy of any gains.
Old Jan 18, 2014 | 06:45 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
I did 3 inch on my whole exhaust, but I plan to swap out the swap out the turbos at some point, but I may have to change the down pipes again, which is why I v banded my whole exhaust so I could drop sections if needed instead of constantly cut and wield.
I don't know if its because the pipe is bigger, or the there is less back pressure or both, but the the turbos spool up sooo much faster and the torque feels even more then just with a tune alone
Old Jan 19, 2014 | 09:36 AM
RaceHorse's Avatar
CL65
Sounds good, I can understand going for a larger exhaust if you wanted the cutouts/ dumps before the mufflers. I only intend to do the downpipes for now. I don't think there is a huge benefit with such a small increase in diameter. But it does make sense in your case to avoid having to cut and weld everything in. Do you have any before and after dyno graphs? It would be interesting to see what is gained though out the curve, not just peak.
