Extended warranty for 2006 cl55
Do you know if I can purchase an extended warranty for the cl55 amg if I buy the car from a private owner?
What is the best proven aftermarket warranty for these cars? Thank you
https://mbworld.org/forums/mercedes-...-warranty.html
https://mbworld.org/forums/5157917-post12.html
14. SUSPENSION: Coil springs, anti-sway torsion bar as well as associated linkage and brackets, ADS pump (where applicable), reservoir, valves, accumulators, valve linkage, suspension pressure reservoir, gas spring reservoir, oil reservoir and cover, oil level sending unit, high-pressure oil hose, distribution valve, switch level adjustment, solenoid locking valve, suspension acceleration sensor, body acceleration sensor, switch load sensor, upper and lower control arms, as well as all suspension links and bushings, ball joints, wheel bearings, wheel bearing seals and air suspension struts.
the best warranties probably fidelity and easycare.
We have talked about this before in another thread.
I have had almost my entire ABC system replaced for free under the CPO warranty. the work was done thanksgiving weekend just a few months ago.
