TCU tune done, car will not start
Current codes I am concerned about are:
B1040 - fault in CAN communication with control unit ME motor electronics
C1022-025. CAN communication with the engine system is faulty
Also the dash is saying instrument cluster display defective and ESP fault in addition to the SRS warning I already had.
Also a few other codes for sunroof not normalized, safety time exceeded for muliticontour backrest, trunk lid angle. I think theses are related to having the seat out and the trunk open for a month but none of these should prevent the car from starting.
Battery is fully charged and has been on a tender so not a voltage issue. Could removing the ECU and TCU as well as lifting out the fuse box between them have caused this issue? I have already double checked the plug ins to the ECU & TCU & they are plugged in correctly. Fuses in that fuse box are all good, have not looked elsewhere yet.
Any suggestions on where to start trying to find the CAN communication error?
Not sure where to even start with so much showing up all at once.
Disconnect everything and slowly start from step 1 and before you install anything check everything over 5 times. You should be all good.
At least pulling the carpet up wasn't a total waste as I wired in my dual dash cam to the main power wire from the battery going to the relay under there while I had it up. That way the dash cam will be on 24/7 unless I turn it off so it will function as a security cam also. Just need to remember to turn it off when I pull in the garage if I'm not driving the car every day.
I'll pull it back out and recheck everything tomorrow. Hate to admit it but I pushed the CL outside to work on building the wall for 2 Fi 18's in my sons Chrysler 300. Told him we would build his sub box as soon as my TCU got back.......didn't expect that to be this long.
One of the cam locking wire bundles to the ECU did not catch and therefore was not making a connection. Simple fix at least! Now if I just had a replacement ribbed idler pulley I could be driving my CL again....... Been parked since the original idler failed over a month ago. Marcin help!
On an even better note I just ordered a set of Niche Essen wheels to replace the EM2's that don't fit over my rear brakes
Now if someone would come out with a 275/35-19 drag radial.....
