CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Strange ABC activity
Old Apr 17, 2014 | 02:37 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
First and foremost the good news, the car holds pressure and doesn't creep down even after a few days. Now here's the issue, every-other time I start up the car, the front end (both sides) will all of a sudden lower and the rear seems to stay up.
What puzzles me is that when I push the button on the dash to raise the car, nothing happens.
I have a Star Das setup coming next week, and I've ordered fluid and the ABC filter.
What do you guys think is causing the issue? Also, why does it say "Airmatic" when it's an "ABC" setup???
Old Apr 17, 2014 | 04:27 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Now that is bizarre.
Old Apr 17, 2014 | 05:31 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
since you dont have any leaks, i am guessing you have knocked a electrical sensor when you hit a pot hole.
Old Apr 17, 2014 | 05:57 PM
Welwynnick's Avatar
2006 S600
Check the level sensors haven't broken
I'll reply to your pm tomorrow!
Nick
Old Apr 17, 2014 | 06:52 PM
Blkvip's Avatar
12' E559
what the ****?! deff want to see results.
Old Apr 17, 2014 | 07:58 PM
s5benzo's Avatar
W221 2013 S550 Rwd, W221 2010 S550 Rwd
Strange seeing an amg cluster say airmatic ... Most likely it needs to be reprogrammed to abc
Old Apr 17, 2014 | 08:45 PM
ricecooker713's Avatar
C63 E63
With the SDS check the actual values of the ABC pump. Sometimes these warnings are for insufficient pressure, signs of a pump going bad. Can't tell any further without scanning it
Old Apr 17, 2014 | 10:44 PM
Grip Grip's Avatar
Thanks guys. I inspected the level sensor as well as other components on the corner with the blow-out and everything checked out. I did an oil change tonight and left the pans off so I can inspect for leaks in the morning. By the way, here's a few more shots of my Airmatic.
